speedometer cable gear
pritch1958
Post by pritch1958 »
I've read some of the past articles and was suprised at the amount of (heated) discussion on this topic. So without opening a can of worms here on gear theory, i'd like to know if a stock C6 speedogear (gear on cable end) will work in a top loader. I'm not as concerned about a correct mph reading as I am with it going together and parts not being chewed up. It feels like a tight hole before the gears even touch. The cable housing wants to stop about 3/8ths from being flush installed. These are both new parts, aftermarket Lokar cable and DK toploader. I'm thinking maybe the metal cable housing end piece may just need some massaging with some 320 grit to make the fit better.
Re: speedometer cable gear
the plastic gear is made for each cable or gear holder. so it may not fit. if the cable is the same it should fit.
Racer Z
Post by Racer Z »
Have you tried places that sell new cables? I only suggest this to see if both types use the same stock number. If the manual and auto trannies call for different stock numbers on the speedo cable, there is your answer.
pritch1958
Here's a pic of the speedo gear and new cable end I'm trying to install in the toploader. Maybe some of you can spot if there's a difference in length or style that i need to go to. The gear off the old C6 cable fits the new inner cable "snuggly" and clipped on and spins with no problem. The guy i just got off the phone with at the ford parts place said there were 2 style gears "long" and "short" but was no help with part numbers. :?
mattjessee18
Post by mattjessee18 »
Does anyone know a website or magazine i can order the gear for the speed cable? I have looked just about everywhere and i can't find one
look on this page. everybody and there brother probably has one. i have one two. it is from a c6 i think. http://www.fordification.com/links.htm
ForingaMex
Post by ForingaMex »
mattjessee18 wrote:Does anyone know a website or magazine i can order the gear for the speed cable? I have looked just about everywhere and i can't find one
You can get them at your local Ford Dealer the only down is that they come in 2-packs. At least here in Canada.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
what about 6 or 12 packs? :lol:
ForingaMex
fordman wrote:what about 6 or 12 packs? :lol:
If you buy any of those you might not have enough money to buy a 2 pack. :wink:
-Jake
i like saki. its pretty good stuff. it has to be warm though or it takes like raw skin on potatoes. kind of.
