Locking rear diff....
torquemonger
Post by torquemonger »
what kind of options do i have for locking the rear diff on my 67? has anyone used a ford EZ locker from Detroit Lockers?
67 mercury 100 352v8
2003 mustang gt 4.6L v8
grease,motors,and octane!!!
1971ford
Re: Locking rear diff....
Post by 1971ford »
Are you talking posi or completely locked? May I ask why you want to lock it unless it's an all out race truck?
Driving a locked rearend vehicle on the street is.... interesting. Worst part is either knowing you are destroying your tires or the fear you are going to snap an axle.
I'd go posi.
-Ryan
torquemonger
limited street use, more two wheel off- road, hunting,fishing,dump-runs etc. don't want to have one-tire-on-fire syndrome
1971ford
Post by 1971ford »
I'd definitely go posi. I've ran open diffs, a posi diff and a locked diff in bumps. Open is fine for street but starts to suck offroad... locked sucks for street, wears tires, and breaks axles... posi is amazing.
For hunting, fishing and dump runs I can see a posi being plenty.
That fact that you'll be doing dump runs scares me even more about having a locked rearend because it only improves chances of snapping an axle because you'll have a lot of extra weight on the rear end.
-Ryan
Caseys71
Post by Caseys71 »
:yt:, I say go Posi as well, it will give you both tires spinning when you really need it and keep you from worrying about grenading axles, and wearing tires quicker than you can buy them when they start chirping on the turns :wink:.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
71fordkid
Post by 71fordkid »
I had a mini spool in my "hotrod" f100. The heavyest thing i ever hauled was a set of 39.5 iroc's on wheels. I wouldnt spool/mini spool/full lock a 9'' if your putting serious weight over the rear end. axel snappage WILL occur.
Id go posi.
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
torquemonger
so what type of posi should i look for? any specific types you've used that you prefer? it won't see much weight on garbage day but i don't like the idea of snapping anything :lol:
mrtleavitt
Post by mrtleavitt »
detroit truetrac. You won't be sorry!
torquemonger
:thup: are they fairly easy to install?
BobbyFord
Post by BobbyFord »
I have a factory trac-loc that works well. When it comes time for a rebuild I will probably replace it with a Detroit Locker.
eggman918
Post by eggman918 »
I have a dodge limited slip in my dana 60 rear it works ok,but if I need to change ratios to suit the cummins/M5R2
I plan on an electric locker in front and a detroit locker in the rear.many moons ago I owned a '69 mach one with a detroit locker and loved it.
Steve.
Steve
no_treble
Post by no_treble »
I just installed a Detroit TrueTrac but haven't gotten the carrier back in the rear-end yet. It was my first rear-end build, but the Ford 9" makes it very easy to set up (preload, backlash, pinion depth). I bought a bearing kit to go with it, and it came with all the bearings, seals, bolts for the ring gear, marking compound, even some red loctite. Kind of pricey for the whole shebang, but I figured it was less than having a shop do it for me even if using lesser components and it will all be worth it when driving this thing on anything uneven/slippery.
Here's a pic of the old setup before work started:
Here's the TrueTrac in the box:
Here it is installed in the cleaned up carrier (the pinion isn't in on this shot and preload hasn't been set yet at this point):
torquemonger
definatly needs more traction...just about got stuck in 8inches of snow in my yard :lol: better rubber will help too.
