- averagef250
Re: T18 or NP-435?
I think the article needs updated. 69 was not the first year for the 435. I've had a mess of 67's with 435's.
Aluminum top= NP435. Pretty simple once you get that down.
Re: T18 or NP-435?
what do you mean by "top", like where the shifted mounts to the top of the trans?averagef250 wrote:I think the article needs updated. 69 was not the first year for the 435. I've had a mess of 67's with 435's.
- fireguywtc
Re: T18 or NP-435?
My 67 had an NP-435. the biggest give away was the "NP" on the side of the trans when I finally cleaned 40 years of crud off of it.
Bill
- Caseys71
Re: T18 or NP-435?
Yes, by "top" he was referring to where the shifter mounts at which is the top-plate of the transmission. Basically if you pull the hump cover the entire part of the tranny you are looking at is the top-plate or "top" that averagef250 was referring to and is aluminum.fordzilla wrote:what do you mean by "top", like where the shifted mounts to the top of the trans?averagef250 wrote:I think the article needs updated. 69 was not the first year for the 435. I've had a mess of 67's with 435's.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
