closed knuckle to open knuckle swap question
hi.i have a 1971 3/4 ton 4x4 and i want to change my front closed knuckle differential and put in a open knuckle unit.any suggestions on what years will bolt up without a lot of modifi cations.thank you
- averagef250
Re: closed knuckle to open knuckle swap question
1976 to 1977.5 F-250 4x4 is a close swap. You will need to update brake hoses, proportioning valve and master cylinder for discs. 1977.5-1979 will work with the addition of shortening the front driveshaft.
great thank you very much
- BRUTUS_T_HOG
i believe you also have to either modify the steering knuckles to accept your tie rod ends or you have to use the 76-77 pitman arm and steering linkages. at least thats what i got out of my research, im doing the same swap when i find an axleaveragef250 wrote:1976 to 1977.5 F-250 4x4 is a close swap. You will need to update brake hoses, proportioning valve and master cylinder for discs. 1977.5-1979 will work with the addition of shortening the front driveshaft.
ASE Certified Technician
ok thanks brutus
- averagef250
There are several sizes of american pickup (non metric 1.5 inch per foot) tie rod tapers. The 76-77.5 stuff should be the same as the all the older closed knuckle stuff. The 78-79 stuff may use theslightly larger tie rod ends.BRUTUS_T_HOG wrote:i believe you also have to either modify the steering knuckles to accept your tie rod ends or you have to use the 76-77 pitman arm and steering linkages. at least thats what i got out of my research, im doing the same swap when i find an axleaveragef250 wrote:1976 to 1977.5 F-250 4x4 is a close swap. You will need to update brake hoses, proportioning valve and master cylinder for discs. 1977.5-1979 will work with the addition of shortening the front driveshaft.
Both of those sizes are on the weeny side, they aren't very far apart and easy to ream larger or slip a washer under the stud to take up some slack so the nut will tighten.
The reason why a guy might want to add the 76-77 F-250 4x4 pitman arm to his older highboy when swapping in any open knuckle front end is because the open knuckle axles use a longer steering arm, the 76-77 pitman is a tad longer to maintain full lock-lock steering.
ok thanks everyone. very helpful
