What gear ratio are you using?
mustanguy
Post by mustanguy »
Hey guys, My '71 f100 LWB, automatic, 390 comes with a 9" 3.25 open gears. My mileage is about 10MPG. I was thinking of swapping to a 3.00:1 ring and pinion i have to get a bit better mileage. What do you think? What gears are all of you running and what's the approximate mileage?
JEF199
Re: What gear ratio are you using?
Post by JEF199 »
Dout it would be a noticeable change. A good tune up and an accurate test will probably get you in the normal range of 12-15. For mine the key is to keep the speed down around 55mph.
You can try some taller tires, (narrow/highway tread)...
  • 1966 Ford Mustang (My First Car)
    • 1972 F250 360 3-speed
      • 1984 Bronco
      1999 Eddie Bauer Expedition
    2006 F250 5.4 Super Duty 4-door
GSequoia
Post by GSequoia »
390 with a C6, 4.10:1 gears, and 9.50x16.5 tires on the drive wheels and I get between 7 - 9.5 with 87 octane fuel.
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
302, 3.03 std trans, 265/75-15 tires, 3.89 gears. Around 12 mpg.
Fordnatic
Post by Fordnatic »
What RPM you running on the highway? With a built 390 and 3:50 gears and some low profile 15" tires I always ran 2400 at 60 MPH and got 12-14 mpg's.
55F100
Alvin in AZ
Post by Alvin in AZ »
mustanguy wrote: My '71 f100 LWB, automatic, 390 comes with a 9" 3.25 open gears. My mileage is about 10MPG.
You need to post your tire size, it can make a big difference in all this.
x2 what Jef said... :)
"...try some tall... narrow/highway tread [tires]"
...like 235/85-16's on 7" wide wheels.
And be sure to test your odometer and always calculate-in the percentage it's off by too.
'75 F150
31.5" diameter 235/85-16E's with 3.50 axle and 360FE +T18
The 3.50 axle gives me a little less MPG than I got with the 3.25 but the power is worth it. :)
'91 Bronco
31.5" diameter 265/75-16E's with 3.55 axle and 351w +ZF
Plan to swap the gearing from 3.55 to 3.73 since it's got overdrive. ...got it all calculated ;)
Alvin in AZ
mustanguy
Post by mustanguy »
I plan on using 255 60 15 on the rear and 225 or 235 60 15 on the front. Radial T/As
Alvin in AZ
mustanguy wrote: I plan on using 255 60 15 on the rear and 225 or 235 60 15 on the front. Radial T/As
So, what diameter are those? :)
Alvin in AZ
mustanguy
Post by mustanguy »
Well It turns out I'm not going to switch to 3.00 gear but when I get the BFGs They'll be a bit smaller diameter. so much for better economy.
Joshpow
Post by Joshpow »
302 c4 with 3.50:1. With a good tune and taking it easy on the go pedal I can get 15 or more mpg. If i play i get more like 10-12!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
cozadlance2
Post by cozadlance2 »
3.73 Dana 60 and C6. by odometer (untested) and gas purchased I get 8.4 mpg w the 200,000 m 360 2v on 245/75/16s on an f250
I am an outspoken person. I will not be quiet to make you happy.
Mancar1
Post by Mancar1 »
68 CS, 390, C6, 4:10 Dana, A/T, 2V. 11 - 12 MPG.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Racer Z
Post by Racer Z »
Stock stock stock. 70 F250; 390 (fresh motor); C6; Dana 60; about 10 MPG. Not sure what the final drive is. It's stock, maybe 4:11.
Gearing up might actually get worse MPG, especially with a load. Cause you will be out of your power band.
BobbyFord
Post by BobbyFord »
Stock 460 ( :D ), 3.50 gears, terrible mileage...
