How good is a small bearing 9"?
- mrtleavitt
Hey guys, just wondering how much better is a large bearing rearend compared to a small bearing? I'm gonna run about 400 flywheel horsepower. I have a spare small bearing housing but I can pick up a big bearing housing for $75. I will have to get them both shortened I think with the slicks I wanna run. What do you all think?
Re: How good is a small bearing 9"?
I think the difference is in the load capacity. Being you are narrowing it wouldn't matter anyway...
- 1966 Ford Mustang (My First Car)
- 1972 F250 360 3-speed
- 1984 Bronco
- averagef250
small/big bearing is reference to carrier bearings, nothing to do with housings right?
- 1971ford
Actually from what I understand is that a small bearing 9inch 's axle tube shrinks down to a fairly small size right before the brakes. Big bearing retains the same axle tube size all the way through.averagef250 wrote:small/big bearing is reference to carrier bearings, nothing to do with housings right?
I've heard this through off-road racing buddies - you don't want to waste your time trussing and doing work to a small bearing 9" because they arn't nearly as strong as a big bearing
-Ryan
- BobbyFord
Big axle bearings are the RUB-1580-EBF bearings. They are large and expensive.
- mrtleavitt
The small bearing housings actually are 3 inch tubes all the way with no tapering. The big bearing housing start larger and they taper down to a 3.25 inch tube. Ya if you're going to dump money into a rear end you need to start with a big bearing but I was just curious if the small bearing housing could handle 400 hp or if I should invest in the large bearing housing.
- averagef250
if you can buy new 3" .250 wall DOM tube for $75 then use the housing you have and replace the small tubes.
Also, using new tubing makes a real nice finished product (no pads/brackets to cut off, no rust pitting, etc).
http://www.panix.com/~alvinj/file12/F100-9inch.jpgmrtleavitt wrote: The small bearing housings actually are 3 inch tubes all the way with no tapering.
http://www.panix.com/~alvinj/file12/F150-9inch.jpg
Both those were built late Jan of '75. :)
Butthead in AZ
