toploader to 429 install
pritch1958
Post by pritch1958 »
I've been travelling lately so not alot of time to spend on the install. But i have made progress and wanted to send some pics. I had to do some grinding/minor mods to the bell housing around the starter ring, and the lower edge of the clutch fork both to clear the headers, and shaved some off boths sides of the Z bar for the alignment but I got the top loader installed. The picture doesn't show it but the shifter is in a super comfortable spot and will be buttoned down soon. Still a ways to go.
Mancar1
Re: toploader to 429 install
Post by Mancar1 »
Looking good :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Fordnatic
Post by Fordnatic »
Nice. I like your gauge panel.
55F100
Bullit
Post by Bullit »
Looking great..nicely done! I'm looking to do the EXACT thing with my truck. Currently getting the 429CJ prepped to go in the shop and could use some tips and tricks you might have learned during your Toploader install...
mrtleavitt
Post by mrtleavitt »
Is that a 4 speed or something else?
forrestbump
Post by forrestbump »
Yes, this transmission is a manual 4 speed.
Read this http://en.wikipedia.org/wiki/Ford_Toplo ... ansmission
Toploaders are considered one of Ford's best manual transmissions..."Bulletproof" is a term you'll often hear associated with this transmission.
Larry
mrtleavitt
Good info, thanks. I've heard the term toploader and just thought it referred to any "car" transmission. I'm only familiar with the truck 4 speeds like the NP435, T18, and T19. I didn't realize that toploaders are only 3 and 4 speed transmissions.
CrypticRacer13
Post by CrypticRacer13 »
Sweet man, looks like its gonna be a fun ride
-Mike-
ECV 1849
