speedo gearing help
madbiker4
speedo gearing help
Post by madbiker4 »
My truck reads 10 mph slow up to about 45 then the faster I go the more off it gets. I know it has the wrong drive gear for the 3.00 gearing in the rearend. my question is will I be ok using any size cable drive gear in order to get the proper speedo reading or do I have to change the gear on the tail shaft to match the cable gear? I see a wide range of cable drive gears available, but only 2 different size tail shaft gears. will any cable drive gear mesh properly with either tail shaft gear?
thanks, -Madbiker4
1972 f100 ranger xlt, 300 cid I6, Clifford performance 6=8 intake manifold, Holley 600 cfm 4bbl carb, Heddman dual exhaust headers, dual flowmaster mufflers, duraspark II, power disk brakes.
Re: speedo gearing help
at the bottom of this list is a chart for each transmission. see what the charts say. http://www.fordification.com/partnos/partnos-index.htm
madbiker4
Post by madbiker4 »
Thanks. according to this chart I will need a 16 or 17 tooth gear depending on how many teeth are on the drive ( not sure if PO used thrans from van or if he used original truck trans ) I currently have a 21 tooth cable gear in it! even if it's not exact it would be nice to be within a few MPH of actual speed. would also be nice to be able to have the mile meter work for milage/mpg checks. thanks a bunch fordman!
Bullitt390
Post by Bullitt390 »
Doesn't matter what the transmission gear is...
If you read 35 when you do 45 then the speedo is off 23%
If you have a 21 tooth gear, you need to speed it up 23%, so the gear needs to be smaller, therefore, that equals 4.83 teeth or...
a gear with 16.17 teeth... suppose 16 will suffice then.
Josh
madbiker4
Post by madbiker4 »
Thanks, I'll have to order one then. I may also get the 17 tooth just in case thought. no point in paying $10 for shipping twice on a $6 item.
Bullitt390
I would just go to the junkyard and scrounge up a handfull for $2
Josh
fmartin_gila1
Post by fmartin_gila1 »
Ford Dealers still carry the gears also.
Fred
ForingaMex
Post by ForingaMex »
fmartin_gila1 wrote:Ford Dealers still carry the gears also.
Fred
Not in stock around here anyway. It's a special order and they come in packages of two.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
