photo request - shift linkage
- Sparx Macgyver
OK,so as everything is coming together, I just wanted to view another C4 linkage so make sure it's all looking good. I'm pretty sure it's alltogether right, but my manual doesn't have the photo's of it. It only states to hook it all together.
[72|F100|SC|Stock]
- Mancar1
Re: photo request - shift linkage
Pic of my C6 wouldn't help. Come on someone snap a pic of your C4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- 70_F100
C4 and C6 should look pretty much the same, as far as external linkage goes.
- Mancar1
If ya think it will help, I will take these old bones and crawl under so I can snap a pic to post . Latter today, still dark as midnight-thirty out.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
I've got a C4 sitting loose in the basement. Are you just looking for the external linkage on the tranny or do you need it with the shift rod hooked to it?
- Mancar1
Thanks, with all the sudden running back and forth to Emergency, Dr. and Hospital I haven't made it under the 68. I think a pic of a C4 would be better than a C6 anyway.sargentrs wrote:I've got a C4 sitting loose in the basement. Are you just looking for the external linkage on the tranny or do you need it with the shift rod hooked to it?
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
I'll get one for you. Can't do it today but I'll be able to tomorrow evening when I get home from work.
Finally! Sorry it took me so long...
And a couple more.......
Hope this helps! RandyYou do not have the required permissions to view the files attached to this post.
