So that's the info on my setup now I have a few questions.
1) 1st gear nobody uses of course for daily driving... but what bout second? Half of the day I started out in 2nd and the other half i started out in 3rd. Any reason not to start in third? Unless you're on a hill
2)How much of a wine should the 4spd make? I'm talking about the typical manual transmission wine when there is compression in the engine and well im not really sure where the wine comes from but it's apparent on almost all older stick shifts. For example I'll be going 45 and this is where my 4.10 gears and 32" tirse start to suck and I get a very loud "wine" from the tranny, espeically if I am not giving it gas. My cab is fully sound deadened and I can't hear the engine at all but this wine is just so overpowering... just wondernig if its normal or if any new parts would lessen the noise?
3) When In 4th gear cruising about 45-50 (where 4.10's and 32's begin to suck) and the engine/tranny starts to wind and compression starts to kick in, If I push the clutch in and then let it out slowly the gears grind a litlte in the tranny. If I dump the clutch the gears don't grind but there is a great force that kicks in immediately and the tires might even lock for a split second... is this just because of the engine's compression? Normal?
It's annoying when I see a red light way up ahead, I push the clutch in to coast to the stop light starting at about 50mph, light turns green, I let the clutch out to give it gas to speed up and BAM either I nearly lock the rear wheels up or I grind the gears.
4)When cruising at just about any speed, foot on the gas or not but clutch not pushed in, there is a little rattle/grinding noise coming from the shifter. It's not really a bad grinding noise or else I would'nt drive it in risk of damaging gears, but it's just a little rattle type of grind... it's annoying. I can grab the shifter and just barely move it around in that gear and i can get it to go away a little bit.
I'll see if i can get my brother to co-drive with his HD video camera and get some video of all of this.
Thanks
