Any truck 8.8 axles made with 28 splines?
Simple question - Were any truck 8.8" rear axles made with 28-spline shafts?
Re: Any truck 8.8 axles made with 28 splines?
No. The 8.8 rearend was never offered in a truck. The only rearends offered include:
- 9" Ford
- 9-3/8" (fairly uncommon)
- Dana 44
- Dana 60 (both a LD 5-lug version and the HD 8-lug version)
- TX69F100
I'm not sure, but look for info on the late 90s Explorers. They came with an 8.8, I believe.
On edit: I believe the Explorers all have 31 spline axles, but this webiste: http://www.therangerstation.com/tech_library/Axles.html says that 1990+ 4.0L Rangers came equipped with the 8.8 28 spline setup.
Say what? Most ford half ton trucks used the 8.8 starting in the mid 80's on up to at least 2000, maybe even still today.FORDification wrote:No. The 8.8 rearend was never offered in a truck.
- Caseys71
, Well I know that rangers/explorers used them at least, not sure on F-150s. I think Kieth was referring to the 8.8s not being offered in our trucks as they weren't offered in our trucks.ScreaminZ wrote:Say what? Most ford half ton trucks used the 8.8 starting in the mid 80's on up to at least 2000, maybe even still today.FORDification wrote:No. The 8.8 rearend was never offered in a truck.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
- fordamericana
"this differential was utalized by Ford as early as 1981 in the F-100 pickup, Broncos in 1981 to 1984, E150 Vans starting in 1983. Mercury's including Capri and Cougars starting in 1986."
Source : http://www.drivetrain.com/parts_catalog ... gears.html
Anywho, what kind of vehicle are you working on?
I likes My FE I does...
OK, I guess I should have clarified myself. I meant it wasn't offered in a bumpside (or dentside) truck. Sorry for the confusion.
- BRUTUS_T_HOG
80's and up f-150s have 8.8s but i don't know if they are 28 spline or 31. i would imagine 31.. but you should be able to use the carrier out of any 8.8
i've read that all rangers/explorers with 4.0 v6 have 31 splines
ASE Certified Technician
Aren't the Ranger/Explorer axles offset to one side? Maybe that doesn't matter, especially given the super-long driveshaft on a LWB bumpside.....
- fordamericana
Slightly...pollock wrote:Aren't the Ranger/Explorer axles offset to one side? Maybe that doesn't matter, especially given the super-long driveshaft on a LWB bumpside.....
I know alot of mustang guys use the explorer and ranger 8.8 axles in their cars... http://www.mustangandfords.com/index.html
I doubt it would interfere with anything or bind anything up, because the angle is slight...
Or appears so...
The explorer/ranger axle is offset to clear the gas tank that runs alongside the driveshaft. My explorer has 31 spline axles, I have heard that some of the rangers have 28's, not sure about bronco II's.
Why not just find a F150 axle that's already got a limited slip differential in it? Those are plentiful and not too hard to find. No need to mix and match different axle parts.
- fordamericana
ScreaminZ wrote:Why not just find a F150 axle that's already got a limited slip differential in it? Those are plentiful and not too hard to find. No need to mix and match different axle parts.
That'd definitely work too. I haven't tried hard to find one, but I was halfway assuming they would be fairly hard to come by. Having done a lot of crown vic junkyarding in the last couple years, i was surprised at how many of those came with posi.ScreaminZ wrote:Why not just find a F150 axle that's already got a limited slip differential in it? Those are plentiful and not too hard to find. No need to mix and match different axle parts.
I'm pretty intrigued by the explorer axle though. I need to measure mine and see how the width compares. Wish I'd have looked into that a year ago - the yards were FULL of clunker'd explorers.
- 48prerunner
off the ranger station websitepollock wrote:Aren't the Ranger/Explorer axles offset to one side? Maybe that doesn't matter, especially given the super-long driveshaft on a LWB bumpside.....
Measurement
Ford Explorer 8.8-Inch
Width between wheel mounting surfaces 59.75"
Pinion offset to right of center 2-3/16"
Pinion length, tube center to U-joint center 11-5/8"
Pinion height, U-joint center below tube center 1-7/8"
Bottom of diff housing below tube center 5-7/8"
Disc brake rotors 11.25 x 7/16"
Brake Drums 10"
Drum brake shoes 7.25 x 1.25" (e-brake)
Distance between spring perches (o/c) 39"
Tube diameter 3.25" (neck down to 2.75")
Axle shaft diameter 1.31" 31-spline
