Front Axle
- maverickfe390
Front Axle
Hey would a 1981 Ford 1/2 ton 4x4 front axle fit into a 1967 F-100 4x4 ?
Re: Front Axle
i know on the 2wd 1/2 tons the lug pattern was changed for a few years. starting in 1980. it was the same as a car. 5x 4 1/2
- averagef250
Re: Front Axle
1980-1997 are TTB. Nothing whatsoever like what you have.
- Hawkrod
Re: Front Axle
That only applies to some 1/2 tons, most were still 5 on 5.5. Only the light GVWR trucks got the smaller bolt pattern. Around here the small pattern seems to be pretty rare. Hawkrodfordman wrote:i know on the 2wd 1/2 tons the lug pattern was changed for a few years. starting in 1980. it was the same as a car. 5x 4 1/2
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Re: Front Axle
really. why was that done? was it becasue of gvw on certain trucks?
- Hawkrod
Re: Front Axle
Yes, light GVWR trucks had the small bolt pattern and heavier trucks had the normal pattern. You would think it would cost more to make two seperate sets of things like brake rotors and axles because except for the size of the bolt pattern, the parts are identical!fordman wrote:really. why was that done? was it becasue of gvw on certain trucks?
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
