convert from manual to A/T in '67
Hi group, I just joined here and looking for a bit of advice. My wife wants to restore a particular 1967 F100 2WD and the first order of business will be swapping the manual tranny with a C6. I'm not at familiar with these old trucks and I'm at the beginning of my research here. Can anyone tell me what I'll need to do this conversion and where I can find the parts? I'm sure I can find a C6 easy enough, there are quite a few on Craigslist. I'm wondering about getting the column shift set up and what about the driveshaft? Thanks, Wade
Re: convert from manual to A/T in '67
parts needed:
short tailshaft transmission with bolt on yoke
correct length driveshaft
automatic steerring column to match you steering box
shift rod from column to transmission
automatic carb
kickdown rod from carb to transmission
you may already have the correct speedo cable
you will also need the floor hump cover to put a c6 in a 67
automatic carb
- bluef250
Try adding power steering and power brakes at the same time as the auto. Try a pick n pull or get a beater and transfer parts.
Welcome to the site and post some pictures.
- Brokenarrow
I'm thinking you'd be better off finding a donor truck with all the parts you need for the conversion, especially if you want to add power steering and power/disc brakes.
BTW Fordman, I replaced a 3spd standard with a C6 in my '68 and it has the low non-removable tranny hump, is a '67 different ?
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
— John Wooden
No, it's just that installing a C6 into a low-hump truck is much easier with the extra room of the add-on hump. A C6 will fit without the taller hump, but it's extremely tight!
- Brokenarrow
Right, There is about 1 1/2" clearance, so it's a pain to remove the transmission crossmember. I have to jack the tranny up against the cab, take all 3 of the trans mount bolts out (the two short ones are a b#%&*) and slide the mount out sideways. Then the crossmember will slide out. I have a tall hump pan in my parts truck but I like the low hump much better.FORDification wrote:No, it's just that installing a C6 into a low-hump truck is much easier with the extra room of the add-on hump. A C6 will fit without the taller hump, but it's extremely tight!
— John Wooden
— John Wooden
i just finished my conv. 65 three on tree 429 / now c-6 check out this shifter it is a lokar (jegs) or (summit) put it all together, and than get driveshaft made i went from a two piece w/ bearing to a one piece alum w/ 1350 u joints seems to hold up to my heavy rt foot . wes
69 bronco 4x4 - 70 bronco tube chassies 4x4 351-w c-6 - 65 f-100 w/69 429- c-6 - 03 ranger 4x4 - 99 f-350 4x4 diesel
- jbohall001
I actually had to trim a little metal out of my way to squeeze my aod in there. Once it was in it had a little room, but couldnt get the bell housing in without cutting a little.
Vi hilser til Day
Vi hilser sønner Day
Vi hilser the Night og hennes døtre
Se på oss nå, med myke og ømme øyne
Velsign oss som sitter her
Vi hilser gudene
Vi hilser på gudinnene
Hilsen til deg; hellige Earth
Gi oss en gave av kunnskap og visdom
og la oss få hender som kan helbrede.
Vi hilser gudene
i didnt go into my install because my truck is a 65 not the same as 67-72 i had to do a lot of cutting , reshaping , had to jack cab off the frame 6 in to clear cross member to slide trans in from rear i figured that was easier than pulling motor . and had to make my own hump . its a tight fit but she fits and works good. wes
the 65/66 trucks use the same hump cover as do the 67-72 trucks. so the floor is the same from 65-79 in our size of trucks.
- Brokenarrow
I pulled the whole front clip off mine, took maybe 45 minutes. The PO had torn it down to paint the frame and undercoat everything so the bolts came out easy.Then I just lifted & rolled the engine and tranny right out and right back into place with a cherrypicker. An engine leveler makes it much easier. The C6 clears the low hump in my truck with no modification.big block wrote:i didnt go into my install because my truck is a 65 not the same as 67-72 i had to do a lot of cutting , reshaping , had to jack cab off the frame 6 in to clear cross member to slide trans in from rear i figured that was easier than pulling motor . and had to make my own hump . its a tight fit but she fits and works good. wes
— John Wooden
— John Wooden
