Made a dumb mistake...threw a part away. Help!
BrantDale
Post by BrantDale »
:cry:
I am hoping that someone might be able to help me, I rebuilt my c4 transmission, went to install it and realized that I accidently threw away the mounting brackets. If anyone has these parts and doesnt need them please let me know, maybe we could work it out. Or if someone know's where I could find these that would be great.
Here is the schematic that shows the parts, the numbers are 6054 and 6068:
http://www.fordification.com/tech/image ... mounts.jpg
Thanks in advance for any help!
1969 F100 Custom Cab
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Made a dumb mistake...threw a part away. Help!
Post by FORDification »
The part marked '6068' is just the transmission mount, and should be available at any auto parts store...it's an expendable item. They're available too at Rock Auto for less than $10. The one marked 6054 is a brace for the mount and really isn't needed. It's job is to keep the transmission mount together in case the rubber breaks/separates. However, I've parted out quite a few trucks and have actually never even seen that piece before, so I think it's something that a LOT of people tend to forget about. Personally I wouldn't lose any sleep over not having it, especially if you're not driving like a maniac or drag-racing.
BrantDale
Post by BrantDale »
Thanks for the help!
cdeal28078
Post by cdeal28078 »
I am pretty sure the 6054 part comes as part of the new mount. Did on the last one I bought anyway
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
mmerlinn
Post by mmerlinn »
Most mounts I have seen have both pieces attached to each other. Those that I have seen detached were mounts that were bad.
6054 makes a good door handle. Four of the door handles in my shop are 6054s bolted to the door.
70_F100
Post by 70_F100 »
I have never seen a mount that came with the 6054 included, and I've replaced a lot of them.
cdeal28078
The ones I remember changing seemed to have it molded into the rubber of the mount just a bit. It would move enough so you could get the bolts started but was still attached. You got me wondering though so I'll have to dig out one or two old ones that might be floating around me junk
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Hawkrod
Post by Hawkrod »
The support was used on all 65 and newer trucks (and also on many 60's cars). It was never molded to the rubber, it was always a seperate part. Due to heat and compression combined with oils, the rubber bonds to it and it seems like it is part of the insulator but it isn't and never was. There are several different versions and two different ones were used on bumps and a few different ones on dents. All trucks were supposed to have them so if you find a truck that does not, it is likely that it had the insulator replaced and, as in this situation, the person did not realize it was a seperate part. Since these trucks are 40+ years old it is impossible to say if the mount you see is original because you would be very hard pressed to tell the difference between 50K miles of dirt and 75K miles of dirt! Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
BrantDale
Post by BrantDale »
Thanks for the input. I ended up getting a part at the local auto parts store. It had a block welded into it so it was just one part. It worked great and my transmission rebuild was successful. Thanks again.
