shifter lever bowl broken
umpalumpa1985
Post by umpalumpa1985 »
72 f100, power steering, c6 trans. I went to put the truck in park today, and the inside part of the shift lever bowl that grabs the notch on the column to move the linkage broke off from the outside part of the bowl. I have called around, and nobody seems to have this part. Unfortunately, there's not a boneyard around here that I can pick one up from. Does anyone have one of these, or know where I can get one, because right now my shift lever is a pair of vice grips. . .
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
~ Rami Belson
Re: shifter lever bowl broken
here is a worn one i have right now. http://www.fordification.com/forum/view ... ifter+bowl
TheEskimo
Post by TheEskimo »
I got mine for around $45 if I recall correctly from LMC. It has been a while so I am not positive on that price. Here was my thread about mine:
http://www.fordification.com/forum/view ... ilit=shift
It has a pic of the new one in the package for the part number if needed. Hope that helps.
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
umpalumpa1985
Disregard. It turns out that the long metal sleeve that turns broke/disconnected/FUBAR'ed from where it is attached to the linkage. Any way to get this and replace it, or do i need a new steering column?
~ Rami Belson
70_F100
Post by 70_F100 »
umpalumpa1985 wrote:Disregard. It turns out that the long metal sleeve that turns broke/disconnected/FUBAR'ed from where it is attached to the linkage. Any way to get this and replace it, or do i need a new steering column?
If you're talking about the shift tube that goes down through the column, I've got an NOS one.
PM me if you're interested.
umpalumpa1985
I am talking about the shift tube, I guess. How is that installed?
~ Rami Belson
70_F100
Post by 70_F100 »
Pretty much the entire column has to be disassembled.
Here's a link to rebuilding the manual column: http://www.fordification.com/tech/3spd-column_01.htm
The automatic column is similar. Here's a schematic: http://www.fordification.com/tech/image ... column.jpg
umpalumpa1985
Hmmmmm. . .can it be done with the column in the truck?
~ Rami Belson
it makes it harder to do while still in the truck.
70_F100
Post by 70_F100 »
fordman wrote:it makes it harder to do while still in the truck.
With an automatic, it's probably not all that bad, at least not as hard as a manual.
Good thing is, it's really easy to pull the column, and you'll find it easier to deal with the Neutral Safety Switch with the column on a bench.
umpalumpa1985
I have nowhere to take it apart right now, and I definitely don't have a bench. I'm on a temporary assignment to Naval Air Station Pensacola, Fl, and I'm living in a hotel room right now. So it has to be done in the truck. If anybody has done it on an auto before, I would really like some advice. Like how to put it in. :o
~ Rami Belson
take the column out and put it on the tailgate.
remove the steerign wheel. loosen but do not remove the two bolts under the tss. unhook the tss wiring under the dash. de pin the wirign connector. mark each place and color as to where they go back into the plug. remove the tss and tss housing from the column. the shift bowl and tube will spring upwards. pull the tube up slightly then wiggle the shifter arm so it releases from the shift tube. pull the shift tube out. reinstall the new tube and spring wiggle the shifter arm again so that the tube seats completely. reinstall the tss housing. those two bolts are fun. put everything back the same way you found it. now the reason it is easier to remove and replace the shifter tube out of the truck is because of the shift arm on the bottom art of the column. do not forget to remove the nss tang from the shifter tube. it sticks out of the column near the bottom.
umpalumpa1985
So when i install the new tube, I just slide it down the column and turn it until I feel it seat?
Thanks for all the help, guys.
~ Rami Belson
it has to go through the shift arm on the column at the bottom outside of the firewall. it will seat or lock into the arm.
here is a picture of a similar shift arm. this is a 78/79 column shift arm i think. but you can see how it keys into the shift tube
