T19 Lubrication
- 67MercM100
T19 Lubrication
I'm getting ready to swap out my T18 for a T19.
I've read that 15W50 motor oil works well for lubrication.
Does anyone have any thoughts on that?
Also, any thoughts on synthetic vs. conventional?
Re: T19 Lubrication
80W90 is more than adequate. And being in Iowa the 15 weight isn't needed, Northern Canada or Alaska maybe, but not the mid-west.
50 weight motor oil is equal to about 110 weight gear oil.
Josh
Josh
- Eric L
Re: T19 Lubrication
If I recall correctly... you dont want sulfur in the lube.. I thinks GL-5 is the bad stuff, GL-4 is ok
http://www.mobiloil.com/USA-English/Mot ... izers.aspx
Re: T19 Lubrication
Novak recommends GL5...
http://www.novak-adapt.com/knowledge/t18_t19.htm
Although their 50 weight claim for FASTER shifts is questionable. Maybe they meant 30 weight engine oil, as 50 weight is heavier than 80w90.
Josh
Josh
- 70_F100
Re: T19 Lubrication
Sorry, but NO WAY is 50 weight oil heavier than 80W90.Bullitt390 wrote:Although their 50 weight claim for FASTER shifts is questionable. Maybe they meant 30 weight engine oil, as 50 weight is heavier than 80w90.
Josh
Those numbers come from running the oil through a viscosimeter, whether it's engine oil or gear lube. The rate at which it passes through determines the numeric value of the viscosity.
Using your logic, 30 weight oil would be heavier than 50 weight.
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
Re: T19 Lubrication
this is always a fun subject isnt it? i will not state any opinions on what is best or what you should use. i will only say this. on the glove box is a sticker that says use 50w engine oil in your manual transmission. now the matter of opinion about 50w back then vs today 50w i will not comment on.
Re: T19 Lubrication
You know more that the oil companies?70_F100 wrote:Sorry, but NO WAY is 50 weight oil heavier than 80W90.Bullitt390 wrote:Although their 50 weight claim for FASTER shifts is questionable. Maybe they meant 30 weight engine oil, as 50 weight is heavier than 80w90.
Josh![]()
http://www.bobistheoilguy.com/cms/index ... &Itemid=55
Josh
- averagef250
Re: T19 Lubrication
Interesting chart there.
In a past life I used a viscometer daily, not complicated machines, we worked in saybolt with lube oils for big gearboxes and diesels.
The commercial machine oils I buy to keep my machines going today are all ISO standard. It's funny how in the ISO standard light, medium, heavy medium and heavy actually correlate to specific oil grades (kinda neat to realize that the "old timers" were actually being specific when you thought they were just out of touch with reality).
None of that experience correlates with SAE motor/ gear oils. having a tranny shop for awhile did give me some excellent insight though. 90wt works and works well. You put 50wt motor oil in it it's your choice. I bet it won't work nearly as well as good 90wt, yes I've tried it, and although it did ever so slightly improve the shift quality in a 435, I was replacing all the bearings and the mainshaft 400 miles later (the next day). So, you use motor oil if you think it's a wonderful idea. If you get motor oil near a tranny I built for you you can take the warranty paperwork you got with it and shred it.
standard, reputable manufacture 90wt is the perfect MT lube. You want to blow $20 a qt? then go ahead and buy full syn.
- 67MercM100
Re: T19 Lubrication
I think I'll just let the shop that's swapping the transmissions decide.
After it's done, I'll ask them what they put in and let you all know the outcome.
- 67F100-390
Re: T19 Lubrication
Just curious, what oil did they use... I know this thread is old, hopefully you can remember.
67 F-100 Custom Cab Short Bed
428ci 4 speed
Finally runs and drives after 14 long years in a field
428ci 4 speed
- 67MercM100
Re: T19 Lubrication
Was finally able to talk to the guys who installed the transmission.
They were fairly sure that they just used simple 80/90 gear oil.
Hope that helps. Sorry for taking so long to find out.
67F100-390 wrote:Just curious, what oil did they use... I know this thread is old, hopefully you can remember.
