Hi, I have a couple of questions about my tranny cover. The cover is broke where the pin ( 7B125 ) goes thru to the base of the shift lever, the part 7207 is not on the cover, is it a gasket or a steel washer? Does anyone know the dimensions of part 7B125? If I can find a new cover is replacing it an in-depth process? The top of the hole in the case is broke and missing, I don't know if it happened a couple of years ago when I had the clutch replaced but whatever the case I was able to find a large washer that basically does what 7207 looks like it is supposed to do, while it keeps the pin from popping out I would like to do a more permanent fix. The way it is now, the cover ( 7220 ) comes loose every so often and it allows oil to leak out and I hate oil leaks. I need a new pin ( 7B125 ) and washer ( 7207 ), can I fill the broken area with weld and drill it back out, or do I need a new cover?
T-18 question
- amishbuggy
- 70_F100
Re: T-18 question
Part #7207 is just a thin paper gasket. Don't worry about it. Most of the time they get thrown away.
As for your other questions, I think this thread from Robroy will answer most of them for you: http://www.fordification.com/forum/view ... hilit=cane
- amishbuggy
Re: T-18 question
Holy crap 70_F100 that is dead nuts on.
Thanks alot.
Thanks alot.
