Trans ID
maverickfe
Trans ID
Post by maverickfe »
I got this trans out of a junk yard any info on it I know is a C-6 for a truck but thats it. I do have the tag for it here are the info off the tag
PGB BJ2 L14
D5TP LA 016919
Thamks
1966 Galaxie Convertable
1967 F-100 4X4 390
1967 Cougar XR7
BobbyFord
Re: Trans ID
Post by BobbyFord »
According to this: http://fordification.net/tech/transapps_73-79trucks.htm
...you have a '75 F100 360 4WD C6
maverickfe390
Re: Trans ID
Post by maverickfe390 »
Thanks for the info didnt there was a differnt web site for that thanks. I pulled from a truck last year but forgot what year and such pluse the junk yard like too put holes in things too drain the fluid so now I have too find a pan for it.
lowellches
Re: Trans ID
Post by lowellches »
Where are ID #'s for later Ford trannys ?
e.g. a PRB-GM
The entire tag reads:
9T 1C3P-kc
PRB-GM
00008705
BD-2B19 (possible that BE may be 8D, I don't think so but it is a bit hard to read.)
thanks
Also, this site shows on my screen in a tiny font, about 8, maybe less, very hard to read - does anyone know why
Lowell
Re: Trans ID
trans tags are on the passenger side of transmissions. the font siz is changeable on the blue arrdess bar to the right the little white A with arrows on each side.
mmerlinn
Re: Trans ID
Post by mmerlinn »
Lowell, your tag indicates to me that you have a 2002 4R100 transmission. Since I don't have a codebook, that is all that I can tell you about it.
