"Dig noise" thats driving me crazy!
So I got one for you guys!Lately Ive noticed when I put it into reverse then into drive I hear a "dig noise" its really weird, Ive tighten up the frame support bolts, it sounds like its coming from the rear maybe. Any ideas?
- 70_F100
Re: "Dig noise" thats driving me crazy!
Universal joint.
Really??? mmm ok so its nothing really to worry about.
The dig noise is the u-joint letting know it time to be replaced, Dig is coming from needle bearing not being there any more and letting the cross move inside the cups. Would replace ASAP.
- 70_F100
hazelnut wrote:The dig noise is the u-joint letting know it time to be replaced, Dig is coming from needle bearing not being there any more and letting the cross move inside the cups. Would replace ASAP.
DIG? grinding? clunk? clank? digging in dirt sound like swish to me. so i need a sound reference.
- 70_F100
My guess is he means "ding"...
eww ding!!! Ill get on that thanks guys!
It's crazy how life gets busy but I'm just now getting back
to working on my truck. I checked the u joints and there
fine I greased them up also.There not loose or anything,
I was told that theres a pin or something that needs tighten inside the diff, it's a Dana 60. I'm not sure how to do this. Have you guys heard of this? Thanks
on the 9 inch rear ends they have a sheild on the rear end where the yoke goes onto the pinion gear. if that comes loose it will ding.
So the middle joint wasn't getting any grease and was dry. I only replaced two now
