Rear axle ratio opinions
Biggut
Post by Biggut »
Just a quick question. Need opinions on what rear-end ratio to run in my 67 with a 390 and a C6. It has the 3.70 right now, and it is WAY too low. I don't use it to pull or haul anything; just a street cruiser. Thanks for your input!
Caseys71
Re: Rear axle ratio opinions
Post by Caseys71 »
How tall of a tire are you running in the rear? Depending on the size of the tire I'd say around 3:25-3:50ish, or if you ran a bigger set of tires in the rear that would lower your RPMs as well and give you the same affect as a higher gear.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
Biggut
Post by Biggut »
Running 23570r15's. Not sure how tall tey are, but I can measure them tomorrow.
mrtleavitt
Post by mrtleavitt »
I would say 3.25. You aren't going to see a huge jump from 3.70 to 3.50- I think that gives like a 250 rpm decrease. Since it's way too low like you say, make the bigger jump to 3.25 gears.
TX69F100
Post by TX69F100 »
Where are you located?
I'm looking to swap to a 3.70 and have the 3.25.
Brent
1969 F100 Ranger 390/C6 <--- Build thread
Biggut
Post by Biggut »
Do you think the 3.0 would be too tall. What usually came stock in a bump with a 390 and a C6? I'd trade you, TX69F100, if it wasn't so far from Idaho to Texas.
gregamorton
Post by gregamorton »
2.75s or 3.00s I would go with for a driver. 2200 -2500rpm or so at 70. You could go with a set of 2.47s if you drive on the highway everyday. Those would put you around 2000rpm or so.
69rangerf100
Post by 69rangerf100 »
i have a 69 F100 it has a 390 manual 3 spd and a D60 with a 3.54 gear ratio
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
Biggut
Post by Biggut »
Thanks to all for your help! I'm not nearly so lost now.
cdeal28078
Post by cdeal28078 »
I have a 3.25 in my 71 F100 460/c6 and it is OK. I had a 3.0 originally and liked it better. Mostly because of the torque of the 460 though. I would say either the 3.0 or 3.25 and wouldn't go any "higher" than those two.
69ranger F100 do you have 16" tires on the Dana 60 with the 3.54? I wonder how much taller your tires are than a 235/15 if any. I think a 235/15" is around 29 inches tall if I remember right, which I probably don't lol
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
