Shifting problems
kelton
Shifting problems
Post by kelton »
Hey guys I am in the process of rebuilding my great grandfathers truck a 1970 F-250 Camper Special.
I have a problem where when in drive the transmission will not shift out of first gear. Now if you put the selector into 1st then 2nd the to drive it will shift into 3rd gear and 2nd respectively. But when slowing down again it will down shift into 1st at low speed but will not upshift so the whole thing starts over again. I have had a local mechanic look at it and he found no problem in the main part but later on wants to look at some thing in the cone part of the transmission that is like a governor. Any ideas what the problem might be and how I personally or the mechanic could fix this?
Thanks for the help,
Kelton
Re: Shifting problems
the cone part? the tailhousing maybe? the modulator controls shifting points. maybe that is what he wants to look at.
70_F100
Post by 70_F100 »
Sounds like either the governor piston is sticking or the pressures are low.
kelton
Post by kelton »
Yes the Tail Housing.. Couldn't remember what it was called. Never messed with transmissions much.
Thanks for the quick reply!!
OK so is their away to check the pressures and do you all know what they need to be at?
Thanks,
Kelton
kelton
Post by kelton »
It has been a while since my last post. I have replaced both modulator and vacuum line for transmission. Still has trouble shifting in to drive and/or 3 gear. Any thoughts?
BobbyFord
Post by BobbyFord »
Pull the extension housing off and remove and check the governor for stuck piston
