Shift Linkage Grommets
- BobbyFord
In case anyone is interested, the part # for the shift linkage grommets on the rod that runs from the column to the C6 trans is EOSZ-7341-B, available from Ford.
They do not list a part number for the upper grommet because originally it was only available on the rod when you bought the rod, but it is the same grommet.
- benden
Re: Shift Linkage Grommets
Perfect timing. I have not logged on for a while and did tonight to find the part number you listed. Thanks.
Bryan
50 chev coupe
56 chev 1/2ton stepside
1969 F100 Custom Cab
1970 F250 Ranger XLT Camper Special
95 F150
05 F350
50 chev coupe
95 F150
05 F350
- OldRedFord
Is the rod you are using threaded on the transmission end or no?BobbyFord wrote:In case anyone is interested, the part # for the shift linkage grommets on the rod that runs from the column to the C6 trans is EOSZ-7341-B, available from Ford.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
the threaded end goes at the top on the column. well for a 67-72 it does. on the 73-79 it goes on hte trans lever.
- BobbyFord
OldRedFord wrote:Is the rod you are using threaded on the transmission end or no?BobbyFord wrote:In case anyone is interested, the part # for the shift linkage grommets on the rod that runs from the column to the C6 trans is EOSZ-7341-B, available from Ford.
Yes, threaded at the column. My truck is very stock.
- OldRedFord
Except for that monster under the hood.BobbyFord wrote:OldRedFord wrote:Is the rod you are using threaded on the transmission end or no?BobbyFord wrote:In case anyone is interested, the part # for the shift linkage grommets on the rod that runs from the column to the C6 trans is EOSZ-7341-B, available from Ford.
Tim
He only added a 100 C.I. to it, thats almost stock. We will just call it stock plus
- BobbyFord
hazelnut wrote:He only added a 100 C.I. to it, thats almost stock. We will just call it stock plus
- ForingaMex
I guess that means the my gear shifter rod is from a dent because the threaded part is in the bottom by the transmission. Learn something new all the time.fordman wrote:the threaded end goes at the top on the column. well for a 67-72 it does. on the 73-79 it goes on hte trans lever.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
- abyars111
Sorry to resurect an old post but I've been searching for this part number. Thanks, BobbyFord. My C6 currently has some rubber bushings, looks like what is used on the 3spd. M/T. Are new retainer clips available?
What do I use for bushings on the kickdown rod. I have the rod but it's not installed.
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
Don't think there is bushing for the kickdown. At least on mine is was tight enough I just used a retainer clip (the half moon looking clips) from any parts store. Used them at the tranny and at the carb. Hope that helps.
My build thread...http://www.fordification.com/forum/view ... 22&t=67317
- abyars111
Thanks, that does help.
If the washer/clip on my shift linkage breaks when I take them off, what do I use for clips to put it back toghether? E-Clips?
Anthony
Yeah, I don't see why it wouldn't work.
