stripped bolt on the intake
No tech discussion, please
f100fordtruck
Post by f100fordtruck »
I have a stripped bolt on my intake, what could I do to get that thang off? I had to and i was able to get the other one off with a smaller socket and some massive leverage but i cant get the other one
I'll get it one piece at a time and it wont cost me a dime...
Re: stripped bolt on the intake
you mean the one that goes into the head? or the one in the carb base ? or is there another one im not thinking about? maybe throttle linkage.
fuzzier1
Post by fuzzier1 »
Heat.
James72
Post by James72 »
vice grips, or grind the head off and deal with it when the manifold is off maybe?
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
f100fordtruck
fordman wrote:you mean the one that goes into the head? or the one in the carb base ? or is there another one im not thinking about? maybe throttle linkage.
uh im gonna say one that goes into the block
well i have heard of welding another bolt head ontop of stuff to get broken bolts out before
f100fordtruck
James72 wrote:vice grips, or grind the head off and deal with it when the manifold is off maybe?
tryed usin vise grips also, probably gonna have to grind it off
Post by cep62 »
fordman wrote:well i have heard of welding another bolt head ontop of stuff to get broken bolts out before
That or a nut , just weld the center of the nut to the bolt with a wire or stick welder.
then you should be able to use a wrench or socket.
f100fordtruck
I thought of that to, I just need to get someone to weld it on for me, I have no welder
FreakysFords
Post by FreakysFords »
I have great luck with the removers (bolt out is what I think the ones Sears sells are called)
fastEdsel
Post by fastEdsel »
I am assuming that you have rounded off the head of the bolt. Buy an engine stud removal tool. Place it over the head, or what's left of it, and the more you tighten it, the more pressure is placed on the bolt and it should come out. It has an eccentric that presses against the bolt head and I have used them on exhaust bolts. If you need more bolt to hang onto then you should weld on extra steel then give it another try. They also work great in close or tight areas. Good luck!
OldRedFord
Post by OldRedFord »
Id give it a shot of PB Blaster and try the vice-grips again.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
f100fordtruck
i was in the process of filin it down when my mom told me to come in and get a shower, i'll have an update tomorow if i got it out
oldschoolrods
Post by oldschoolrods »
I have used Image these to get me out of a jam working on stuff out in the middle of nowhere. If you can heat it up a little then spray it down with pb blaster or oil and that will help break it free.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
fastEdsel
Post by fastEdsel »
Excellent choice! :thup:
