FT vs. FE 4WD oil pan
two-bit
Post by two-bit »
I did a search and found one member who talked about using an FT pan on his 4WD FE engine.
Has anyone else done this? good or bad results?
I have fairly good access to a number of FT pans and am wondering how good of an idea it would be.
Thanks in advance.
Two-bit
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
Redcap
Re: FT vs. FE 4WD oil pan
Post by Redcap »
FT pan is a full sump, need to get the pickup too. Can't remember how many quarts. Pretty much a direct swap, if I remember correctly.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Read this for more info with pics:
BumpWiki: FE/FT Oil Pan, Dipstick & Tube Data
wont the full sump FT pan have the same problem in a 4wd as the 2wd frotn sump pan? it will hit the axle on some bumps in the road? sellign a full sump pan would be a good thing to do too. others what the larger capsity pans for thier trucks.
