Larger Diameter Wheels
I've been looking at new wheels for awhile now. Man are they expensive . I am currently running Eagle alloy 589's with 285 75 16. I was wondering if anyone is runing 17" or larger wheels on there rigs and if they would share some pics. Thanks
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- td
Re: Larger Diameter Wheels
mine are 20x8's and the rear are 20x10's
- ezernut9mm
doug, do you still have those 8" wide wheels we were talking about a couple of years ago???
td-although your wheels look great (and what I didn't say) was that my trucks is 4x4. If I ever had a 2wd it would be like yours. Looks real good.
ezernut- yes I do.
Doug
ezernut- yes I do.
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- fomocoguy
How about 16.5's?
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
Hey I had a set just like those one time! Actually I'd like to see a set of 17x8 or 9 on a highboy. I don't want any of the modern spoke stuff but getting tired of my eagle alloys.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- Redcap
I gotta ask...why larger diameter? 15, 16, 16.5 tire choices aren't cuttin' it?
- Wes
.Redcap wrote:I gotta ask...why larger diameter? 15, 16, 16.5 tire choices aren't cuttin' it?
Need min 16.5 to clear big disc rotors. Tire choices in 16.5 are getting fewer and fewer. Comparing 35" 16.5 to 35" 18's there will e less side height, which means less flex and better handling. Two of the reasons I considered bigger wheels
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
I just thought it would be a little different. I like the 285-75-16's I'm running and there is nothing wrong with the wheels either. I just was kicking around getting new wheels and was wondering about a larger size like the newer trucks are running. I do not like the bead design of the 16.5 either.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- zakt
What size tire are you going to run on the 18x10's?
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- zakt
probably 37" toyo tires but have thought about the 35" but with the crew cab I think the 37" will look more proportional
1972 Ford F350 crewcab
