EFI 300 straight six PICS*** last year...
- FoMoCo
Finally got my camera going. Took some pics last year of my EFI 300 swap. I drive this truck 30 miles round trip each day. I get milage no less than 20mpg. The pics are self explaining. The pic with the fellow removing the 360 is my cousin Rob. The final pic is camping two weeks ago. Happy trails.... Nick
the payoff...
the payoff...
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- dablack00
Re: EFI 300 straight six PICS*** last year...
We are going to need a little more info on the swap than that!
Did you delete anything in the EFI stuff?
What kind of fuel pump did you use?
What trans and rear gears are you running with that 300 to get 20mpg average.
What MPG do you get on the highway (at what speed and RPM)? What MPG in town?
Is everything stock on the 300 or did you hop it up any?
thanks
Austin
thanks
Austin
MORE INFO! ................PLEASE.
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
- FoMoCo
Okay , I may have been a little vague. The engine is a bone stock 87 F-250 with about 60,000 miles. The EGR was left in tack for milage purposes.I used a mustang 5.0 smog pump eliminator pully, wich fit with no modifications The air-in-head injecting was removed, pump was seized. The original 69 wiring harness was untouched. I just needed a switched 12 volt souce to power the EEC, Ignition, and fuel poump relays. I removed the tank and TIG welded a 6AN male fitting on the bottom center of the tank pointed at a 45 degree towards the seat. For the return line, I used 6AN and connected it to the original fuel feed line. The 6AN was connected to the engine with Russel brand Ford quick-connect to dash 6 adaptors. The fuel pump is a Walbro GSL 392 mounted on the rear most cross member. The porpose for mounting the fuel pump so far back was to eliminavte the pump whine in the cab. The pump is gravity feed since the feed line is welded to the bottom of the tank. The 360 V-8 core support opening was too wide for the 300's rad. I replaced the 360 rad with a 69 f-350 dually w/ 300cid application wich was same dimention as the stock 360 rad. The down pipe is a modified Magnaflow Stainless stock replacement for 87-94 apps. The exhast is 2.5 back to a Dynamax super turbo RV muffler with a stock exit 2.5 tailpipe.
As far as drive line. The trans is a Ford built TOD light duty 4 speed overdrive, Commonly found in 85-87 ford f-150's with 300's. The drive shaft front section was shortend about 2.5 inches. The rear gear is a 3.30 the tires are 30x9.5 BFG long trails. The EEC is mounted standing up between the e-brake and column.
ASK AWAY...
Nick
ASK AWAY...
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
Your trucks is AWESOME! any build pics of the wiring,etc..? What kind of mileage are you getting? Thanks
-Lance
-Lance
- 65_Slick
Good looking build! How's the TOD drive? Do you by chance have any pictures of the the trans?
Thanks
Marty
Thanks
Marty
- austin
wow id love it if my 300 had efi
great job
great job
- wickedinhere
WOW love that 6.
You can pay more but you cant buy better.
- FoMoCo
Here's some pics of the Ford TOD next to a Long nose slip yoke 3 speed. The TOD trans is a direct swap for the slip yoke 3 speed but not the bolt on yoke 3 speed. It;s a good driving trans, no low gears, tall OD. I'd say 1800 RPM's going 60mph.
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- craftsman
What year was the doner vehicle? Was the eec already for manual trans? Very nice job.
I know from experience that tranny with the flat top is one tough S:O:B:,Ill say Ive put one through pure ____,and it just kept coming back for more.
94 Ford F-150 super cab
300-6 eod auto,changing to NP-435
- rjewkes
Would it be the TOD in te cougars and tbirds with the 3.8? The trans in the cougar is tough.
fuelly.com
fuelly.com
Do you have any more pics. My kids and I are putting a 88 300 efi into a 67 F-250 4x4. We are currently using a NP 4 speed. It will get a ZF 5 speed. The problem we are having currently is the upperintake and the fire wall. The truck had a very tired and thursty 360. Any help would be great. Thanks.
What mods did you have to do to the ECC, I am using a 89 4.9 efi going into a 72 what extras did you have to do to weed out the crap that came with the stock motor?
Thanks
Thanks
I am running the same drive train as you (with 3.55 gears). I think it is the best kept secret! the 300 six is great but the efi. version is awesome. It doesen't do anything great, but it will do anything, within reason!
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
flh shovelhead
rigid evo
