My clutch assembly is complete and works wonderfully. Thanks for all the great advice!
One remaining question I have is regarding clutch linkage adjustment.
In the 1972 Ford Truck Shop Manual, on page 16-03-3, I read this:
The 1 to 1.5" of free play they're talking about there is in the clutch pedal itself, not any other part of the linkage. And according to these instructions, 1.5" is really better than 1".
I messed around for a while with the adjusting nuts and finally achieved a position where the pedal free play was about 1 and 1/8". With this in place, I measured the play between the tip of the clutch release rod and the fork (with the fork already positioned so it was just touching the T.O. bearing to the P.P.). The play there was about 1/4".
If I remember correctly, I've heard from several Fordification members that with the T.O. bearing just barely touching the P.P., I should have about 1/8" of free play between the tip of the clutch release rod and the fork.
So, which amount of play is best? Is it better to follow the Ford shop manual with my 1 and 1/8" of free play in the pedal, or reduce the play so that I have 1/8" of play between the T.O. bearing the the P.P.?
Two more questions:
- Is it true that the free play decreases as engine RPMs increase? Does this mean that I should adjust the clutch differently if I plan on doing >4k RPM shifts?
- What's the big deal with this free play anyways? Why not have the minimum free play that would keep the T.O. bearing from touching the P.P. when you don't want it to, like 1/16" of play or even less?
Robroy
