edelbrock performer plus cam for 390
Jarred Hodges
Post by Jarred Hodges »
I am going to put a new cam and lifters into my truck. It has a basically stock 390 except for headers and a 4bbl carb. I have found the edelbrock performer plus and I am thinking of getting it. I am looking for opinions on it. Here is the link
http://www.summitracing.com/parts/EDL-2106/
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
Brokenarrow
Re: edelbrock performer plus cam for 390
Post by Brokenarrow »
That seems like a pretty mild cam to me. Really it just depends on what your're doing with the truck, where you want the "power band" :hmm: . I'm building a 390 real similar to yours, .060 over, headers, edelbrock intake etc. :thup: and I'm going to run a cam with .484/.510 lift, 270/280 duration, and I thought IT was a little mild. FWIW here's a link with factory FE cam specs.
http://www.mercurystuff.com/fe-camshaft-specs.html
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
TNIceWolf
Post by TNIceWolf »
Jarred
That cam is essentially a pulling and towing cam. It is made to produce low to mid range torque to break a heavy load loose at low rpm and accelerate it thru the mid range. Its not high end performance really but it will really perk the engine up in the low to mid rpm response range.........it's the same set i am using in my 360. Be advised to go with the valve spring set recommended for the cam set as well.
Presently in the stable
1969 Ford F-350 DRW
Jarred Hodges
I don't plan on winding my engine a lot. I rarely go over 3500 rpm so it should be great
convincor
Post by convincor »
you can alway's do better than a Edelbrock IMO.
Look at CompCams and download there cam selector- http://www.compcams.com/CAMQUEST/
There #'s may be a bit exaggerated for HP and torque but it'll give you and idea.
Otherwise http://www.oregoncamshaft.com/ will grind a nice cam for you. and there not much more than a "off the shelf".
Or call Barry at http://www.survivalmotorsports.com/index.html He won't steer you wrong.
"Still Plays With Trucks"
70_F100
Post by 70_F100 »
Convincor, what do you think of the CompCams 268H?
convincor
Post by convincor »
I've got a XE274 in my car and I'll tell ya, you know it's there and louder than the Crane 941 I ran before.
Using the CamQuest-
268H comes up with 345hp @4500 and 436ft.lbs @ 3500
XE262 comes in at 349hp @ 4500 and 442ft.lbs @ 2500
XE256 comes in at 345hp @ 4500 and 453ft.lbs @ 2500
I wouldn't hold Comp to these #'s but It just shows bigger isn't alway's better.
If it were mine, I'd probably look at the XE262. not to crazy but you'd hear it. :2cents:
70_F100
Post by 70_F100 »
I bought a 268H off ebay a couple of months ago at a steal.
I wanted something that would give me a noticeable idle, but not rock the engine out of the frame.
It's going to be a 390 with about 10:1, Edelbrock Performer RPM (almost stole that, too, with only a couple thousand miles on it), Holley or Edelbrock 600 CFM carb, headers and a C-6.
Whatcha think?
70_F100
Post by 70_F100 »
Aren't the Edelbrocks just repros of the old Carter AFB's? Those were SWEET back in the day when Carter built them. I had a Carter AFB Competition Series on a 66 Impala, and it brought that engine to life!!!
If the 1850 is the 600 with the small metering block, I totally agree. They're "OK" when they are new, but put a few miles on them, they go to crap. Try to rebuild one, and it's NEVER right after that. Had one cause a major engine fire on a 75 F350 with a 460 that I used to drive as a service truck.
The one you pointed out is one of the better Holley units. I didn't know they still made them with two "full" metering blocks. I had a couple of those back in the early 70's, and they were sweet as h@!!.
Good suggestion, my friend!!
convincor
Post by convincor »
Yea, kind of. But there Edelbrocks, not the old Carters... they worked good on Chebbies. :wink:
70_F100
Post by 70_F100 »
Gotcha.
Edelbrock must have bought the patent from Carter, since they look almost identical.
Those carbs were the "$#!+" in their day!!!
george worley
Post by george worley »
I agree that the Holley 1850 600 usually doesn't work well after being rebuilt, I used genuine Holley rebilt kit amd still couldn't get it to run right. I have a Holley 780 that has two metering blocks that I bought back in the mid 80's on my truck that has been rebilt several times and still works fine. I guess Holley calls that carb a 750 when it has a secondary metering plate. I don't under stand why the different CFM rate. I know that 780 CFM is on the large side for my 390 but it has Vac. secondaries and works out good. It is a non emission carb. The primary side is basically a 500 CFM two barrell.
70_F100
Post by 70_F100 »
The 780's I remember were single-pumper, side-hung float carbs with vacuum secondaries.
The 750's flowed just a little less air, but had mechanical secondaries, center-hung floats and dual pumps.
convincor
Post by convincor »
I ran a 3310 750 on the 72 C/S I had last year. The truck came with a Edelbrock on it but lacked power.. Tried the 750 and it was night and day. I agree it's big for the stock 390 but it ran better than the Edelbrock.
This is why I keep it around for a spare...
