good intake manifold 351W
flatblack
Post by flatblack »
was wondering if i could get any reviews on a good aftermarket intake manifold, planning to run at least a 750 cfm carb,
specs on the engine are here:
http://www.fordification.com/forum/view ... =3&t=43867
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
court1100f
Re: good intake manifold 351W
Post by court1100f »
well the one I wanted when I had the 83-85(not sure which anymore) was a Weiand Stealth Bad ass intake man suppose to act like a dual plenum at lower RPM and a Single Plan at Higher RPM..............I sure do wish they made them for the FE series
Weiand Stealth
These dual-plane manifolds combine the low end throttle response of a 180 deg. design with the top end power you'd expect from a single-plane manifold. Their effective range is from idle to 6800 RPM, and they are best-suited for 350-400ci engines.
cdeal28078
Post by cdeal28078 »
When my truck had a 351w in it I also ran the Stealth. I pulled a Performer to out it on and it made a good deal of difference in the seat of the pants feel.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
court1100f
so how noticeable of an improvement did you get going from the Performer to the Weiand Stealth intake????
cdeal28078
Kind of hard thing to describe. I could feel a change for sure and it was noticeable. I'd say it felt like 10hp over all but then again who can say what 10 hp really feels like? No help I know lol
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
