think i may have found the issue guys
sacramento_ford
Post by sacramento_ford »
well, after all this time, getting stuck ,stalled in trafffic, after repplacing, cap rotor, fuel lines and even fuel pump and rebuilt carb. omg.!!
well, i was thinking it was the coil, me and others thought it was heating up, well. after stalled at a flea maket, kept tuning over.
i hooked up a expernal power source with a house plug and got my battery charger , charged the battery a little and it started up.
all this time im thinking coil was over heating. it just wasnt getting enough juice. whatcha think ,,, alternator>??
70_F100
Re: think i may have found the issue guys
Post by 70_F100 »
If it's been spinning over okay, it's very doubtful that you have an alternator problem.
Think about it. If you charged the battery a little, that means that you let the engine cool a bit.
Still points to a problem either with the ignition or fuel system.
sacramento_ford
im thinkin, its getting fuel , as checked by someone. reason i thinkit may be alternator casue when it stalled. then i waited a while and then the battery would natrually recharge eough to start it after it sat awhile,.
70_F100
Post by 70_F100 »
If it sounds like the starter is getting weak when this happens, it probably is. It may be getting hot from the exhaust.
Batteries don't "naturally" recharge themselves. They do develop a "bit" more power, but if it's as bad as you've been saying, the battery/carb/coil/etc probably isn't the problem.
VERY simple way to check that. Take it to Advance or AutoChina and have them check the charging system. Three minutes, you have an answer on that one, and it's free.
Still doesn't explain the stalling...
sacramento_ford
wish i had the cash to just toss it in the shop. i need my truck for work,waaaaaaaaaaa!!!
70_F100
Post by 70_F100 »
I wish the same thing, and I just need mine for fun!!!
Even moreso, I wish I was local, and I'd figure out your problem!!!
garinger
Post by garinger »
Does this truck have the funky half moon plastic connector at the coil? If so discard and replace with eye terminals at both the + and - terminals.
sacramento_ford
garinger wrote:Does this truck have the funky half moon plastic connector at the coil? If so discard and replace with eye terminals at both the + and - terminals.
yeah i tool it off already.
im goonna start with the coil. i should know better than rely on some guy at autozone,18 bucks . to wipe it from my mind, plus it will run better anyhow with fresh part
70_F100
Post by 70_F100 »
So, since it had the "half-moon" connector, are you running a Duraspark system?
sacramento_ford
no im not
i thought you said you had a electronic box of some kind on it.
