rookie mistake, new counsel
i have an all original F100 Custom just needing a little TLC. I was removing the carburator(1st time in my life) and twisted the fuel line that runs out of the front of the carburator to the fuel pump. I don't want braided line, would like to keep my truck original. Its a 302 2barrel manual transmission. Any advice about where to find a suitable replacement.?Thanks from a new member.
Re: rookie mistake, new counsel
pick n pull or national parts depot, also autozone or kragens has alot of old truck stuff.
- sideoilerfe
it's just 5/16 fuel line .You can get it in bulk and bend it to your application. Use your old one as a template.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- m-mman
Just remember that the 5/16 steel tubing needs to be bent with a tube bender.
Just one inexpensive example from Hrbor Freight.
http://www.harborfreight.com/cpi/ctaf/d ... umber=3755
You can get them anywhere. Various styles and prices.
The universal tube you buy will most likey need to be cut and flared also
http://www.harborfreight.com/cpi/ctaf/d ... umber=5969
Bending and cutting tubing is a skill. Like everything on our trucks, there is a learning curve, thats why they are a hobby.
A fuel line is a good place to start and get some practice.
1969 F-100 Custom Cab 302 T-85 Overdrive, 3.70 equalock & factory 16" wheels
- DuckRyder
While you can bend it from bulk, you can also buy exact reproductions from NPD, Inline Tube and several other suppliers in both regular and stainless steel.
- suavematt
NPD's a good source... I'd also order yourself a FREE LMC Truck catalog. They've got everything "stock/option" & a few other aftermarket goodies in there as well.
Later.
~ Suave'
Later.
~ Suave'
Name's Matt. I'm a southern' Boy with a love for the Lord & Carb'd Ford V8's hahaha... Anything else you wanna know... Ask ; )
1979 F-100 Super-Cab/Long-Bed Work-Truck [300 I6, C4, Ford 9" Rear]
1993 Ford Ranger, single-cab short-bed [2.3L 4-banger, 5spd trans, 7.5 rear... Full-time Convertable ; ) ]
1972 Ford Mustang [351-Cleve' (being built, still workin' on it), C4 auto, Ford 9" Rear]
