1972 Ford F250 Saddlebag gas tanks
Hey All
Well the ford i thought was a 71 turns out to be a 72 and i just got a better look at it tonight and removed all of the junk from out of the Bed and found two saddlebag gas tanks in the back and wondering if that was something that was a good idea to have... what if some one hits me on the side . Having the truck taken into the shop tommorrow to see what could be wrong before we start it up the first time after sitting for 8 years.
Also i thought the Truck had olny 49999 miles on it but could be 149,999. The break pedal is kind of worn out and has parts of the rubber missing and underthe hood is kind of rusty.....
- sideoilerfe
Re: 1972 Ford F250 Saddlebag gas tanks
Are the tanks IN the bed or underneath the bed? do you have the factory Aux tank as you stated in a different post that it was a Camper Special which usually means it did. Post some pics if you can.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
The tanks are in the Bed on both sides...... I will get up some picks as soon as i can.. Thanks for the response.. Totaly new to all of this i feel dumb not knowing things abou the truck,, but every one here seems pretty good about helping out. Pics will be up soon
Oh not sure if this matters but i know there is another tank that looks like it was or is behind the seat int he cab.
- sideoilerfe
The cab tank is supposed to be there. If you have the saddle tanks in the bed and they work, I'd leave them. I have saddle tanks under the bed on my '68 and eventually the driver side one will be removed to make room for the aux tank out of my '72.
As long as they work and don't look bad, there is no reason to remove them.
Oh ok that is good advise.. I was just not sure. I have never seen them before in the bed. have them under the bed. thanks for your help. I know iw ill be posting more once i get it back from the shop and start decieding what i want to do
if they are in the bed and not under it they have been added by someone. get rid of them. if they are inside of the bed.
Hey
They are in the bed one on each side. Right up tight to the front of the bed. They are painted in the same color as the Truck>... Were they not an option you could get when youpurchased the truck?????? They are like rectangle. I will post picks once it get it out of the shop...
- sideoilerfe
All saddle tanks are "added by someone." If they work there's no reason to get rid of them unless he wants to.fordman wrote:if they are in the bed and not under it they have been added by someone. get rid of them. if they are inside of the bed.
- sideoilerfe
No.cadillaccoo wrote:
... Were they not an option you could get when youpurchased the truck?????? ...
Some dealers added saddle tanks under the bed with a little aluminum door riveted to the bed. I've seen others inside the bed as you are describing.They work the same way. I think inside the bed would be safer than under the bed/outside of the frame in a side impact anyway.
well it is my opinion to get rid of anything in the bed. to make room fo rbed space. as far as outside the rail tanks . i think they would be more dangerous than inside the frame rail.
- sideoilerfe
re-read my post, then re- read yours then you'll (hopefully) understand what I said.fordman wrote:well it is my opinion to get rid of anything in the bed. to make room fo rbed space. as far as outside the rail tanks . i think they would be more dangerous than inside the frame rail.
we are talking about the same thing. exactly. my truck has those junky under bed tanks on both sides outside the frame rail and they are more dangerous. i also like my bed to be clear of un nesasary junk. the incab tank is the only thing i have ever used on my truck though. so i have not had any need for extra fuel tanks. this is my opinion to get rid of those tanks. becuase they are either dangerous if outside the rail or in the way if they are inside of the bed.
Thanks for the advice
