Hey all
Been ages since I've been on here... Welp' my Big-Ford (1979 Super-Cab/Super-Long 8'6" Bed) Has been over-heating when I'm pulling stuff around town, or draggin' stuff while working etc... It's got a 351M/C6... I just don't think the Mechanical Fan is doin' it justice. Sooo... I've "acquired" a Big Dual set of electric-fans that flew off a late-mod F-250 when it got in a wreck down-town a while back ... Still works great! My question is should I hook it up as a pusher, if front of the Rad' behind my Grill... or as a Puller, & mount it inside my engine bay ? Would love to hear your thoughts opinion.
Thanks!
~ Suave'
Electric Fan... Pusher or Puller?
- suavematt
Name's Matt. I'm a southern' Boy with a love for the Lord & Carb'd Ford V8's hahaha... Anything else you wanna know... Ask ; )
1979 F-100 Super-Cab/Long-Bed Work-Truck [300 I6, C4, Ford 9" Rear]
1993 Ford Ranger, single-cab short-bed [2.3L 4-banger, 5spd trans, 7.5 rear... Full-time Convertable ; ) ]
1972 Ford Mustang [351-Cleve' (being built, still workin' on it), C4 auto, Ford 9" Rear]
Re: Electric Fan... Pusher or Puller?
Puller. More efficient.
- suavematt
10-4... Think I should replace the mechanical fan with it, or keep it too & just run em' both?
thanks, later.
~ Suave'
thanks, later.
~ Suave'
If you put the electric fan on the radiator as a puller the mechanical fan won't pull any air through the radiator. Just pull it off and gain a couple hp.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- suavematt
Welp' took the mechanical fan off & got the electric unit on there & wired up; I tossed the thermostat & just hard-wired it to the ACC so as long as the Truck is running the Fan is too. So far so Good. I think this should likely fix my over-heating issues... But I'll also be picking up & installing an Auxiliary Trans-fluid cooler too... & maybe a remote-oil filter with a finned oil-cooler plumbed into, after the filter, just before the oil goes back into the engine... Might as well do all I can to keep the ol' boy "cool" & me happy
Later all.
~ Suave'
Later all.
~ Suave'
- suavematt
Hmm... So where/who is the Best place to buy a "Heavy-Duty" 4-Core Radiator? LMC's prices are just more than I'm willing to spend for a Rad'... Check all my local J-yards & every F-250 or higher/Van has been robbed of theirs... I'm wanting to set this thing up as a 1-ton Hauler... Got an 8-lug Dana 70 that will eventually one day find it's way under the Truck... I got a FORD OEM F-350 Oil-Cooler system that will eventually get installed... gonna get an auxiliary Trans-Cooler system on there too.
I pull a lot of trees/logs, blocks, tile, etc... stuff that makes normal F-150's squat & most chev's look like Low-riders
Thanks Later.
~ Suave'
Thanks Later.
~ Suave'
