what is this?
72bumbee
what is this?
Post by 72bumbee »
What is this. Came out of the breather line to the valve cover.
Mark Twain
ToughOldFord
Re: what is this?
Post by ToughOldFord »
PCV valve.
Positive Crankcase Ventilation. :thup:
Re: what is this?
yep . shake it . does it rattle? if not buy a new one. it wouldnt hurt to get a new one anyway. even if it does rattle.
Sam I Am
Re: what is this?
Post by Sam I Am »
There is supposed to be a rubber grommet in the top of at least one of the valve cover holes that it fits into, big end down.
The flared end sticks out of the valve cover and connects with a vacuum hose (not fuel line) to a similar nipple somewhere near the base of the carb or sometimes to the air cleaner housing.
JMcTurnan
Re: what is this?
Post by JMcTurnan »
We call them reburners, it will take the fumes, and anything It can reuse and put it back into the carburetor to reburn it.
72bumbee
Re: what is this?
Post by 72bumbee »
Wow, I sat and stared at this thing for the longest time. Like I said, I have been away from this stuff for a lot of years, and if it wasn't in the 69 f100 i USED TO OWN OR THE OTHER PRE 1960'S CARS i HAVE OWNED, IT just looks foreign to me. Thanks for all the info, it all makes sense now!
Mark Twain
72bumbee
Re: what is this?
Post by 72bumbee »
yes it still rattles fordman! and I believe i will replace it when I go to hook the carberator back up.
Mark Twain
72bumbee
Re: what is this?
Post by 72bumbee »
If my unemployment check and wife sez I can LOL!
Mark Twain
72bumbee
Re: what is this?
Post by 72bumbee »
Okay, I mutilated the hose that connected the PCV to the carb. I tried replacing it with good old fashioned rubber fuel line. The old hose was pre bent and stiff. needless to say, the PCV is not seated tight in the valve cover. Is there somewhere I could buy a replacement hose that is rigid and pre bent like the old one, or should I just put the old one back in?
Steve
Mark Twain
Re: what is this?
i know these guys have coem up with aux fuel tank filler hoses. http://www.greensalescompany.com/
ToughOldFord
Re: what is this?
You can do THIS.
72bumbee
Re: what is this?
Post by 72bumbee »
I guess That is my solution! I can't find that rigid stuff anywhere. How crazy is that. Now my only dilemna is wether to use copper or silver flexi tubing! They all look so chic. :-)
Thanks again ToughOldFord
Mark Twain
