a little guy with a big hammer moved into my engine
67_p_car
Post by 67_p_car »
on the trip home from the farm, the old gal started banging! shoot
I just put in some non-oxygenated fuel in it - but I can't imagine that would have done it
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
St. Paul — Zumbro Falls, Minnesota
Re: a little guy with a big hammer moved into my engine
is it the lifters or rocker rattling from the pinging of fuel? or is it a hard knock from the lower engine. my guess is the pinging from the fuel you put in. i dont know what kind of fuel you are talking about so i am guessing.
67_p_car
Post by 67_p_car »
non-oxy is fuel available here w/o ethanol and is only for use off road or in cars eligible for "classic car" licensing. please - oh - please be bad fuel! :cry:
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
papabug71
Post by papabug71 »
My experience lately with Off-Road fuels has lead me to believe they are garbage. My in-laws have a 1000+ acre ranch & they dont even run "red" diesel in their equipment anymore. Its full of trash & plugs filters way to quick.
I would drain the tank & lines, prime it with good gas & hope for the best!!
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
frankensteined_67
Post by frankensteined_67 »
explain the bang better. is a band like pounding you fist on a table, or a small knock like tapping your fingers on the table. :hmm: .
At this point Id say it could be a lifter, piston, rod, even a valve with a broken spring.
67_p_car
Post by 67_p_car »
it sounds like your avatar!
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
67_p_car
Post by 67_p_car »
like in the subject line - it sounds like someone with a hammer inside the engine - towards the firewall - and probably somewhere from the top of the piston up - don't know what to do with the gas once it's out? I don't have another car to put it in - sure as hell not putting it in the porsche.
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
just add more gas to what you put in there that will thin it out if its the problem. a real hard knock up top. maybe a rocker shaft bolt came loose or something its hard to tell without hearing a knock what it is. i think its hard to tell anyway.
frankensteined_67
O come on put it in the expensive car :D
if its that loud sorry to say its a rod knock. thats my conclusion with out hearing it.
ok with new gas in start it and if it still makes the noise pull on of the spark plug wires one at a time the noise will change. when it does that will be the cylinder that has the prob. that will get you a starting point.
67_p_car
Post by 67_p_car »
really not expensive - it's sort of a vw with lock washers! but it is pretty finicky.
I like the idea of pulling a plug - I'll try that
Called wife (she is in SD at a conference) and the gem said "well, we didn't pay that much for it - so i guess we will just have to fix it!" which is better than "I told you that piece of junk would never run right!"
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
67_p_car
Post by 67_p_car »
ok - so now what? replace it? what will be the easiest swap another 240? -- 302 s are a dime a dozen - how much monkeying around will it be to drop it in?
shoot - I don't have time for this.
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
more descrption and a little checkign htis and that we could help better. its nto going to just blow up with some different gas in it. how is the oil level. if it shows on the stick keep working on it. its possibly not destroyed.
67_p_car
Post by 67_p_car »
well the oil was down 2 quarts by the time I got home (75mi) ran smooth down and was getting great mpg. the way back I drove 60mph all the way and didn't notice the banging until I was coming down the hill into st. small. it also ran pretty hot the whole way not to sure exactly temp - but hotter than I like. I think the radiator may have a leak.
found a guy in Winona with a 66 240 w/20K on rebuild that he will install for 500 - it is in his van right now and he is planning a 390 swap - so I can hear and drive it - his has a 3 od on the floor transmission on it that I have been told I have to take -- but I don't think I want to cut a hole for it - what do you folks think?
all-in-all I still love this truck!
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
4th effie n counting
Post by 4th effie n counting »
well if you get his 240, you don't need his transmission, so no holes need be put in your floor. Now he's saying he wants you to take the trans? If so say ok put engine in truck and trans in the bed : )
67 F100 240 I6 3spd now gone :(
1971 F250 LWB FE power by FORD
67_p_car
Post by 67_p_car »
that's the plan my friend, now chance really ruining the engine by trying to drive it to Winona from the Cities or have it towed? - my jetta doesn't have a hitch or I'd try that.
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
