holley 1940
holley 1940
we started dismantling my carb to clean it and install a new float. well, come to find out the place where the idle air adjustment is busted out on the inside. we go to buy a new one and can't find one. what would be a good replacement for a 300 L6?
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
Re: holley 1940
A 390 ?killakobra wrote:what would be a good replacement for a 300 L6?
Re: holley 1940
. not if you want mileage.
- BobbyFord
Re: holley 1940
Moped?
Re: holley 1940
i see we have some militant 390 lovers. nothing wrong with that but i ment what would be a good replacement carburetor?
Re: holley 1940
Ohhhhh.
I don't know.
I don't know.
- Sam I Am
Re: holley 1940
Replace the Holley with the same kind of Holley?killakobra wrote:we started dismantling my carb to clean it and install a new float. well, come to find out the place where the idle air adjustment is busted out on the inside. we go to buy a new one and can't find one. what would be a good replacement for a 300 L6?
Fix the old one with JB Weld?
Re: holley 1940
we can't get a new one and it's around the idle air adjustment where it broke so i doubt jb weld would work
Re: holley 1940
well we found out that the ford 1110 1 bbl off of the 240 manifold i got along with my green truck kind of works. i bought a rebuild kit and we're going to hope for the best
Re: holley 1940
can you get any kind of other carb from the parts store? have you checked ebay.
Re: holley 1940
i suppose but that's more than $17.49. i didn't know if there was any preference between the ford, the holley, or the carter so i thought i would ask.
Re: holley 1940
turns out that my ford 1100 is from a 223. that may be why i can't find a rebuild kit for it. time to buy another carb i guess.
- jzjames
Re: holley 1940
Try to find another Holley 1940 if you can. I think it is the best option of the three that will fit on your 1 bbl intake.
Thats what Ive got on my truck and gives me good gas mileage and performance. It is a replacement carb for these trucks, not that uncommon and you may find one on ebay if youre patient. I just rebuilt mine about 6 mos. ago and it was a little tricky but luckily it went together without needing a third hand, and is working good. The option I have come to think would be good is to put on a offenhauser intake on the six, and a small Rochester carb mounted on it.
Re: holley 1940
i've rebuilt the 1940 that i have, problem is that it's broken. after a quick look i found 1 on ebay but i don't have the cash for it right this second. :\
