Volumetric Efficiency
MaxKlinger
Post by MaxKlinger »
Anybody know what a stock 360 FE is rated at in terms of volumetric efficiency?
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
averagef250
Re: Volumetric Efficiency
Post by averagef250 »
Probably around 60%.
MaxKlinger
Really? That low? I was thinking it would be in the 77-83% range.
Would going to an aftermarket intake manifold improve VE?
Tony
averagef250
Ve is typically advertized at peak HP. A 360 is likely more efficient below 2500 RPM than most carb engines whereas it sucks at 4000 RPM peak HP ratings.
