428 crank in 390 Need info.
I recently got offered a 428 crank to put in my 390 . I need some info on the pros and cons of this. And tips on what to do or not do if I go this route.
- ok68crewcab
Re: 428 crank in 390 Need info.
I believe the 428 crankshaft is externally balanced where as the 390 is internally balanced so you will have to address that. A 390 with a 428 crank, is that basically a 406 or a 410 cubic FE?
2 Blessed 2 Be Stressed
- court1100f
Actually I was doing calculations to this effect last night and a 406 is a 428 block with a 390s 3.78" stroke Crank and a 410 is a 390 with a 428s 3.98" stroke Crank so you would have to get the right Pistons BUT a 410 is a BAD ASS engine and would definitely be worth it
- 390F100
I'll take it if you dont want it...
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
- BobbyFord
You'll need the externally balanced flywheel and harmonic balancer if going with the 428 crank.
- convincor
the 428 crank can and should be internally balanced same as the 390 crank when used to make a 410.
and if your replacing pistons this should be done reguardless. It will cost a little more than std. balanceing because they will need to use heavy metal(mallory) to get enough weight.
more on the subject-
http://www.fordification.com/forum/view ... =428+crank
"Still Plays With Trucks"
- mrtleavitt
Go for the crank swap!!! You will need to adress the flywheel balancing issue. The harmonic balancer is the same as any balancer on a 390, 360, 428, 352, etc. They are all neutrally balanced. You can either get a externally balanced flywheel (autozone has them available for around $100) or get the crank balanced. If you can find someone to balance the crank go that route but I know that many shops don't like to do that on the 428's so they might suggest the off-set flywheel.
