eng removal
hotrod ford
eng removal
Post by hotrod ford »
can i remove my 300 from the np435 to remove it from the truck or will it be better to remove them as a unit? i would like to know because, how hard will it be to reinstall the eng if the tranny is still in the truck? :thup:
1971 Sport Custom SWB: 360/C6 3.00
1965 Ford Falcon 4Dr: Inline 170 3sp
NM5K
Re: eng removal
Post by NM5K »
Mine has a T-18, but when I changed engines I left the tranny in place.
The trucks with 4 speeds have the top removable access in the cab.
I tied a thick rope around the tranny, and looped it around a 2x4 that
I placed across the floor. That pretty much held the tranny in place
when I removed the engine. The 435 should be much the same I think.
So my vote is to leave the tranny in place.. Or at least that is what I did.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
Jarred Hodges
Re: eng removal
Post by Jarred Hodges »
I always pull motor and tranny. It is easier that way imo
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
flyboy71
Re: eng removal
Post by flyboy71 »
I pulled my 240 six and 3 speed tranny as a unit. It was interesting. I had to remove the tranny crossmember to let it drop down to clear the cab. As it came out the engine pointed skyward and the engine leveler did nothing to fix that. Maybe I didnt have the chains on the right places on the engine but Im not even sure where they should really attach.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
hotrod ford
Re: eng removal
so, if the tranny doesn't need to come out and i leave it in will it be a pain for me to attach the eng to it when i put the motor back in?
NM5K
Re: eng removal
Post by NM5K »
It can be a bit tricky, but overall it's not that big a deal.
The main thing is to carefully line everything up real close,
and then just nudge it on in. You can't "manhandle" one into place.
You have to finesse them.. As an example, I had a friend of mine
over to help me stab the engine to the tranny. But he kept trying to
manhandle the thing into place, and between the two of us, we didn't
get it that night. "It got dark on us, so we just quit for the day."
But I came back out myself the next morning, and carefully lined
everything up, and bingo, slid right into place.
But!, that was not the end.. Dummy me forgot to put the cover
plate on.. :doh:
So I had to pull it back apart and put the cover on.
So I had to restab it, and using the same finesse method, it plopped
right back in. :hd: I had much better luck on my own, than I did
with the helper.. :/
hotrod ford
Re: eng removal
sound good then, tomorrow the 300 will be coming out. thanks NM5K. :thup:
flyboy71
Re: eng removal
Post by flyboy71 »
Not to hijack the thread but is it hard to get the engine and tranny together? My grandfather told me after I pulled mine apart that I would have a deal of a time getting it back together. He said I would need another tranny shaft to stick in through the clutch to line everything up but it will still be a job. He has done this before but Im trying to understand exactly what he means.
-Jeff
hotrod ford
Re: eng removal
no go right ahead, the more info the better.
wildcard
Re: eng removal
Post by wildcard »
They make a line-up tool that most any parts store should have. Beats another shaft. And the last one I bought was less than $10. At least my daughter didn't say anything about me owing her. But then, I also didn't get any change back either. Hmmm, have to ask her about that.
george worley
Re: eng removal
Post by george worley »
In a pinch I have used a piece of a wooden broom handle. :2cents:
hotrod ford
Re: eng removal
i almost have it off but stopped. should have removed the eng from the bell housing or the bell housing from the transmission?
wildcard
Re: eng removal
Post by wildcard »
Did you drop the trans crossmember? Had to do that on a 67 Chevelle once to pull it all out at once. Good luck. Nothing like experience to learn from.
hotrod ford
Re: eng removal
nope, put a jack under the tranny and removed the engine. lowered the tranny onto the cross member after the engine was removed.
OldRedFord
Re: eng removal
Post by OldRedFord »
hotrod ford wrote:i almost have it off but stopped. should have removed the eng from the bell housing or the bell housing from the transmission?
Bell housing from the engine. :2cents:
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
