429 big block??
429 big block??
Any one know if a 1970 f350 came with a 429....And will the engine and tranny drop in a 1970 f250??? http://seattle.craigslist.org/sno/pts/1264561737.html
Re: 429 big block??
fairly certain that they didnt come factory in pickups, at least not f100-350s. easy swap though. worst part for me was having the driveline shortened. cake!
Re: 429 big block??
it will fit and it has everything you need right there. maybe even the driveshaft.
Re: 429 big block??
I don't see any problems. If the guy would let you I would get all the motor and frame mounts, tranny cosssmember and driveshaft. If the driveshaft is to long it is not hard to shorten it. I would grab it quick before someone else gets it because that seems like a great deal
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
- BobbyFord
Re: 429 big block??
429 was never offered in a pick up. 460 was first offered in '73, I believe.
- AK F100
Re: 429 big block??
I found a nice 70 Thunder bird wirh a 429/c6 and was thinking about buying it for the engine and tranny and then parting out the car. I'm sure I would take some extra stuff to mate it to a 73 4spd that has a 390 in front of it now though.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
Re: 429 big block??
That looks like an FE to me. Look at the water pump.
Locate approximately as shown.
- MadMaxetc
Re: 429 big block??
True, but we all know that the dealers would swap in what ever you wanted...as long as it was in production.BobbyFord wrote:429 was never offered in a pick up. 460 was first offered in '73, I believe.
Most likely it is a retro fit.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- OldRedFord
Re: 429 big block??
The bell housing bolt pattern is different between the 429 and the 390.AK F100 wrote:I found a nice 70 Thunder bird wirh a 429/c6 and was thinking about buying it for the engine and tranny and then parting out the car. I'm sure I would take some extra stuff to mate it to a 73 4spd that has a 390 in front of it now though.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- BobbyFord
Re: 429 big block??
The engine perches and mounts necessary to install a 385 series engine in an F-series truck were not available until 1973.MadMaxetc wrote:True, but we all know that the dealers would swap in what ever you wanted...as long as it was in production.BobbyFord wrote:429 was never offered in a pick up. 460 was first offered in '73, I believe.
