new carb, do i put gasket sealer on carb
sacramento_ford
Post by sacramento_ford »
installing neew carb, im putting it on engine tommorw, is gasket enough. id hate to put goopy gasket sealer. will the 4 bolt be anough or will it leak air without
gasket sealer.
Re: new carb, do i put gasket sealer on carb
it should be enough with just the gasket yes. unless you have a vacuum leak after the carb is on then you might need to remove the carb and put soem sort of silicone or soemthing on it. but that probably wont happen unless the carb spacer plate is warped. and if it is replace it instead of sealer.
Sam I Am
Post by Sam I Am »
You should never need sealant on a carb.
But you should always use a fresh base gasket whenever you have the carb off.
The gasket gets squished and hardens over time. If you reuse it, it won't seal as well.
And don't overtighten the 4 nuts or it can warp the carb base.
sacramento_ford
Sam I Am wrote:You should never need sealant on a carb.
ok thx
averagef250
Post by averagef250 »
I like to coat both sides of the gasket with light grease or vaseline. This will make the gasket seal better and it'll come right off perfectly clean if you ever remove the carb.
Jarred Hodges
Post by Jarred Hodges »
just the asket and 4 bolts should work fine. I don't think I have heard anyone use gasket sealer on a carb
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
mrsnicks
Post by mrsnicks »
I'm a little anal. If it has a carb spacer I put a gasket on the intake and one on top of the spacer so every "connection" gets a gasket.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Sam I Am
Post by Sam I Am »
mrsnicks wrote:I'm a little anal. If it has a carb spacer I put a gasket on the intake and one on top of the spacer so every "connection" gets a gasket.
Patrick
Nothing unusual about that, that is how it is supposed to be done.
ezernut9mm
Post by ezernut9mm »
averagef250 wrote:I like to coat both sides of the gasket with light grease or vaseline. This will make the gasket seal better and it'll come right off perfectly clean if you ever remove the carb.
works great with water necks too. :thup:
thebannister8
Post by thebannister8 »
[quote="Sam I Am"]You should never need sealant on a carb.
:yt:
