Manual Choke on Holly carb.
1970f100x
Post by 1970f100x »
Ok, so I'm pretty sure the carb i have on my truck is original. It's a holly with a manual choke. The problem is, when I was taking off the air filter, I was playing with the choke, and I noticed that when i moved the cable lever back and forth it didn't do a thing to the valve, all it did was increase and decrease the rpms. I could manually open and close the choke, but i need to be able to do that from inside the cab. There aren't any parts missing, what do you suggest I do? Is it a possibility that I just need some carb cleaner to loosen it, or what?
sideoilerfe
Re: Manual Choke on Holly carb.
Post by sideoilerfe »
1970 should've been a hot air choke and not a manual.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
take a pic of it. i am unfamilair with the holley carbs.
miner3do
Post by miner3do »
ill get a pic of my manual choke when i get home mine is a Holley 4bbl with a manual choke. it could be that the cable is loose or broken some where along the line
1990 Mazda Miata 1.6 turbo
2010 Audi S4
1967 F100 4x4 4spd
miner3do
Post by miner3do »
soo i finaly got around to taking some pics hope they might help you
this is the wire that controls the choke
it heads back into the cab
2010 Audi S4
1967 F100 4x4 4spd
something just isnt grabbing something have soem one pull the choke while you look at it and maybe you can see whats not moving it.
fastEdsel
Post by fastEdsel »
Someone correct me but didn't all these trucks come with 2bbl Motorcraft carbs? I would suggest your carb and your intake are not stock but aftermarket. But I have a lot of experience with manual chokes on both 2 and 4bbl Holleys. As Fordman mentioned, have someone gently pull the choke button on the dash to see if the butterfly valve moves. From the picture it looks to me like this was a conversion kit from an automatic to a manual choke. That is the reason you have a fast idle when the choke is partially pulled. And that is a good thing to have for a warm up. And the reason I know that is that the adjustment screw for the fast idle is just visible between the rear mounting screw and the cam nut on the butterfly actuator. Don't mess with that screw! It's just fine. A little WD40 on all the cable points and moving parts will keep it working just fine. :thup:
flyboy2610
Post by flyboy2610 »
Some trucks did come stock with a 4V carb. And I think Holley was one of the choices. So it could be stock.
Red Green
you'd better be right.
sideoilerfe
flyboy2610 wrote:Some trucks did come stock with a 4V carb. And I think Holley was one of the choices. So it could be stock.
They were 2bbl Autolite carbs.
