famous carb issue -sac ford guy
sacramento_ford
Post by sacramento_ford »
something has come to my atttenton, befoe the rebuilt, the truck was floooding. and stalling. installed carb, and it was squirting up the needle valve, seem no matter what i do seems like im just gettig alot of fule too fast. that would explain burnt gas vapor coming from pcv valve, what would cause the fuel from coming way too fast, the cause may be a cure.
montana_hiboy
Re: famous carb issue -sac ford guy
Post by montana_hiboy »
Install a fuel pressure regulator and set it around 5psi, adjust accordingly if needed.
Jim
'75 Ford Highboy 390 4spd
sacramento_ford
odd cause i never had any issues before, also could it be the fuel pessure sender., or is this not possible casue i have a mechanical pump
