Fuel Gauge on New Fuel Tank
tod-hog
Post by tod-hog »
I did the fuel tank swap to the mustang tank between the rails. I'm having some issues with the fuel gauge however. It will only read half full even when completely full. Have those of you that have done this swap had this issue and what did you do to remedy?
billkris07
Re: Fuel Gauge on New Fuel Tank
Post by billkris07 »
I am having the same problem....suspect its the sending unit.....there is a great resource on this website to help check your sending unit.....
scott123
Post by scott123 »
The top of the rheostat wiring in the sender has a tendency to get corroded. If you dismantle the sender and wire wheel the wire wrap with a dremel it will work.
1972 Camper Special
5.0 EFI TFV-IV Ignition Auto O/D
tod-hog
Post by tod-hog »
The sender is in the tank, right? It's BRAND new!
BobbyFord
Post by BobbyFord »
Where did you guys get your tanks? I just bought a 22 gallon Mustang tank and I'm going to do the swap when I'm done welding the bed seams.
mkpj1
Post by mkpj1 »
It's all about ohms. I can't remember what the ohms are for old ford gauges,...something like 60 empty, ~25 half full, ~10 full. That's for the old gauge. the newer sender may be 25 full , you see??, I don't know for sure. Your wire may be the wrong AWG,..ie lower or higher resistance. Research it, that's the problem, hopefully. don't hold me to the ohms above, i can't remember. Are you sure the sender is not adjustable?
Talk to me about this tank guys, where's it go, I don't want a tire in my bed??
Ken
Greenville, SC
68 F100 LWB 390
67 LTD 390(4V T-bird Special)
74 Bronco 351W
"I sincerely believe... that banking establishments are more dangerous than standing armies, and that the principle of spending money to be paid by posterity under the name of funding is but swindling futurity on a large scale." --Thomas Jefferson to John Taylor, 1816. ME 15:23
BobbyFord
Post by BobbyFord »
mkpj1 wrote:...Talk to me about this tank guys, where's it go, I don't want a tire in my bed??
The tank goes under the bed, behind the rear axle, between the frame rails (where the spare goes).
mkpj1
Post by mkpj1 »
Thanks Bobby, That's what I was afraid of. I like my spare were it is.
S-code Huh,..lucky *******!
Trade you a 74 bronco with a 351W? np435??
Ken
Greenville, SC
68 F100 LWB 390
74 Bronco 351W
BobbyFord
Post by BobbyFord »
mkpj1 wrote:...S-code Huh,..lucky *******!
:D
flyboy2610
Post by flyboy2610 »
http://www.fordification.com/fuel-sending-units.htm
This might help you troubleshoot your sending unit.
Red Green
you'd better be right.
