72 f350 radiator in 69 f100?
i have a chance to grab a very large radiator out of a 72 f250...i was wondering if this will fit in my 69 f100 just fine with no problems?? thanks
Re: 72 f350 radiator in 69 f100?
look at the mounting points on the side of the radiator. it probably has then half way between the front and back of the radiator. so you will have to get the super cooling mounts from the old coresupport to mount it. or make some brackets. but then you will also need to adjust your fan depth to make sure the fan doesnt hit the radiator. here a pic from the site.
