Where water temp send unit on the 300 six?
Jchimbolo
Post by Jchimbolo »
My truck was swapped with a 300 or something six cylinder engine from a 240 I believe. This truck has no defroster or heater system as it is an old ice cream truck, 1969 ford f100.
Where does the temp sending unit go? I bought the factory part. The spot I thought on the right side of the block turns out to be a drain and is not deep enough for the probe. Or where can a put one?
wickedinhere
Re: Where water temp send unit on the 300 six?
Post by wickedinhere »
On mine if your standing in front of the truck its on the left side right under the # 6 cylinder intake runner. Here is a pic its under the last hole on the left its hard to see but thats were its at.
You can pay more but you cant buy better.
Jchimbolo
Post by Jchimbolo »
thanks i'll check.
