460 flexplate
460 flexplate
The flexplate on my 460 was cracked and now after a trip into town it has grenaded, leaving me stranded with no gears at all. Are the flexplates year and engine specific? Or even transmission specific, i have a c6 in it. ive seen in parts catologes that some flexplates are balanced and some i guess arent. I dont know which flexplate i need. Please help i just put the truck on the road and my chevy friend is talking alot of ****. thanks dale
- Hawkrod
Re: 460 flexplate
Easy to tell, 79 and newer are externally balanced and 78 and older are internally balanced. From an assembled engine it is very easy to tell by looking behind the harmonic balancer. A 79 and newer engines have a large counterweight and 78 and older just have a smooth shaft between the harmonic balancer and timing cover. Hawkrod
Counterweight picture from eBay:
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Re: 460 flexplate
thank you sooo much!!! I know my 460 does not have that little counterbalance behind the harmonic balancer. So internally balanced flexplates wont have weights on them and externally balanced ones will? is that correct?
- BobbyFord
Re: 460 flexplate
I've heard 390 flexplates will work on 429/460's
Re: 460 flexplate
awesome. thanks guys
