Hello all,
I am an fe enthusiast, but I haven't played around with one in a couple of years. I was doing some fe research today and came upon a quote (wiki) about some dude named "Chuy" in Agua Calientes, Mexico who made a 450 HP 352 back in 1965-66. Of course this cite was not supported and there is no mechanical breakdown for the engine. I am wondering the truthfulness in this citation. 450 hp out of a 352 with 1966ish technology? For a truck to haul workers in the back (see wiki citation)? Long story short...I want to know how to do this!!! I think it would be great in my '67 F100 CS. Let me know what you guys think.
450 HP fe
- averagef250
Re: 450 HP fe
Sure, put a 4-71 blower on it and run 110 octane fuel. Detroit blowers were 30 year old technology in the 60's.
Naturally aspirated with pump gas you cannot make 450 HP with a 352 and use it to haul anything in a pickup.
Re: 450 HP fe
427 SOHC marine application were made in that vintage, and they were 625hp with 1 4barrel carb.
352 is a completely different beast, but hey at least the block was close
450 hp from a 352 ? no way man. build yourself a 410 torque monster.
Collecting 67-72 Ford/Mercury trucks since 1980, collecting 73-79s since 1990 when the 67-72s started drying up. Now I'm culling the herd. None of my 67-72 will ever be for sale! They will need a big hole in the ground.
- My427stang
Re: 450 HP fe
I agree, Jim Dove just made 480 hp in a 352 for Engine Masters competition. However, it ran high riser heads, a big cam, and wouldnt have the low end torque to work every day. It would be a drag motor.averagef250 wrote:Sure, put a 4-71 blower on it and run 110 octane fuel. Detroit blowers were 30 year old technology in the 60's.
- bumpside
Re: 450 HP fe
http://picasaweb.google.com/terryhege/3 ... directlinkaveragef250 wrote:Sure, put a 4-71 blower on it and run 110 octane fuel. Detroit blowers were 30 year old technology in the 60's.
I think 450 is doable without to much effort. I just ran this on my Comp cams software and I made 410HP with a NON roller hydraulic cam. I selected 660 cfm carb-- 1.80 intake valve--1.50 exhaust valve-- a dual plane intake-- headers-- and ported and polished heads with 10 to 1 compression on pump gas. Nothing wild. This was set up fot a 4x4 truck at 4500 lbs and a daily driver. The 410 hp is at 5500 RPM and torque is 442ftlbs at 4000RPM
Try this link. It is a little fuzzy, but if you mag it to 150% I think you can read it. I couldnt get the info to transfer directly, so I scanned it and sent it to Picasa.
1972 SWB Ranger XLT
`We'll hold the distinction of being the only Nation in the history of the world that ever went to the poor house in an automobile.' (Will Rogers)
- Hawkrod
Re: 450 HP fe
Unfortunately a desktop dyno is fantasy not reality, the guys who have been building them for decades will tell you it is tough. 450 HP from a 390 is doable but is near the limit of "reasonably easy" and yet the desktop dyno's say 500 is easy. The reality is each engine design is a bit different and the desktop dyno is a compromise. The FE's are capable of power but not as simply as the desktop dyno makes it seem. To make 450 from a 352 you will need great heads, cam and intake as well as compression carb and ignition. Really, the only parts of a 352 you can use as is are the crank and block, all other major components will need to be aftermarket or heavily modified originals. As noted above, Jim Dove only got 480hp out of a seriously modified race engine. The heads cost more than most of us pay for out trucks even before they were modified! LOL Hawkrodbumpside wrote:
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- bumpside
Re: 450 HP fe
Thanks Hawkrod,
I am a small block guy, and I keep forgetting the Fe is a different animal. Dino.....................? No it cant be! Say it isn't so! When we want HP from a small block, we just spin it a little more and pray we get to do it again
bumpside
bumpside
1972 SWB Ranger XLT
