P/S
- maverickfe3
P/S
Hi I know this has been taked too death so here it goes. I have a 1967 F-100 4X4 that will have a C6 in it what I would like too know I got a Bronco gear box that fits on the out side of the frame would this work and is there more I need to do this job?
Thanks
Thanks
- heep70
Re: P/S
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- maverickfe3
Re: P/S
Well thanks heep I will just do that.Where at in washington are you at Im in CDA.
- heep70
Re: P/S
Bonney Lake. Where is CDA, Canada?
Greg
- maverickfe3
Re: P/S
Nope Coeur D Alene Idaho near Spokane
- Wes
it has been talked about not sure who has done it on a f100. link http://www.fordification.com/forum/view ... ng#p215754 . I used a bronco box on my F250. I believe it is easier to do a f100 than a f250. link to my thread some of the pic links are broken. http://www.fordification.com/forum/view ... =9&t=15700
what year bronco where you considering ?
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
- maverickfe3
Re: P/S
Thanks Wes,What Im trying too do is take a Bronco gear box and put it on my 67 F-100 4x4 .
- Doug F
Re: P/S
Hey Brother of the 67 F100, I am doing the swap right now. My box is an 84 truck box and is turned around on the inside so the pitman arm is to the rear like it was originally. Stay tuned, I am doing a full how-to on it.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
Re: P/S
This is a 4x4x2 box from a 78. The images will show the swap from manual to p/s on a 70 f100 4x4. Rear lower bolt hole is correct. Red arrow shows grind area yellow arrow shows hole to use. Minor grinding to cross member tabs. Front and upper rear to be drilled out. Be sure p/s box is 2" behind radiator core support mounting hole. Using a full indexed pitman arm allowes you to set arm every 10 degrees.
- Doug F
Re: P/S
Looks like we have the same box...
I also got a collapsible intermediate shaft to connect the steering column to the new box with CV joints.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
- averagef250
Re: P/S
That is most definitely not an 84 truck box. Those are U-joints, not CV joints.
Re: P/S
i have the same box doug. i got mine from a 79 4wd. i was looking at it today. i was goignt o put it on my 4wd but i notcied my holes are the same as the holes on the 79 4wd box i have. my holes are of a 2wd box. so i will have to drill new hole to mount my 79 4wd box. if my box will work at all beause of the pitman arm direction on mine. it is backwards from what i will need.
- Wes
Re: P/S
do these p/s boxes turn the same direction as the manual boxes ?? Do f100 steer off the driver side or the pass side. I used a 78 Bronco box on my F250, looks se direction same as posted pictures. The box needed to have the rotation reversed to steer the F250 correctly. I swapped a 2by rack and worm gear in the bronco box, to make it turn the direction I needed.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
Re: P/S
Doug F wrote:Looks like we have the same box...
That is the 4x4 box Doug, be sure the 2 wheel drive worm gear has been installed. When input shaft is turned right, pitman arm must swings right
- Doug F
Re: P/S
The box's number is E4 blah blah... Thus an 84 steering box.
Yes, they do turn the same way as the manual box.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
