is there a difference between a mustang & mountaineer motor
woodyp
Post by woodyp »
I'm in the process of putting together a Motor from an 88 Mustang. I have an Intake, MAF sensor, computer and wiring harness from a 93 Mustang I was planning on using. I just found a 96 Mountaineer in the junk yard and was getting ready to pull the GT-40 heads and intake. beyond that is there any difference in the 5.0 from the mountaineer and the mustang 5.0 engine such as cam?
71 F100
73 Mustang Conv.
willowbilly3
Re: is there a difference between a mustang & mountaineer motor
Post by willowbilly3 »
Not sure on the cam profile, you got the good parts with the heads. The exploder exhaust manifolds are some strange creatures.
rubiranch
Post by rubiranch »
The Mountaineer used cast iron GT40P heads with angled spark plugs and no AIR ports in the rear of the heads. The intakes were also a low profile. Ford used the GT40P heads to try and compensate for the low profile intake and restrictive exhaust. I believe the cams were the same. :2cents:
The exhaust headers from the 5.0L HO will not work with the GT40P heads due to the angled spark plugs. :nono:
:fr:
72 F-250 CS XLT 390 C-6 4.10 40k miles
You don't shoot to kill, you shoot to stay alive.
I don't carry because I have to, I carry because I get to.
http://www.fordification.com/galleries/ ... ?album=514
